Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 26-12-2015, 22:46
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: pic: Recycle Rush Re-design Part 2
If using only pneumatics for a thethered robot you will probably need more air tanks than it is worth to try to reduce the losses from long runs of wire. Lifting a tote with pistons requires a lot of air because of the weight of the totes in addition to the amount of stroke needed to lift them high enough. To stack at the feeder station you need to lift them considerably higher than the usual of about 13-14"
