Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 21-12-2015, 12:12
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
[FTC]: Tri-Wheel design
We are thinking to go tri-wheel route. Did anybody made a successful tri-wheel design to climb the mountain?
Unread 21-12-2015, 17:16
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: [FTC]: Tri-Wheel design
We considered doing it, but in the end we were dubious as to whether we could handle the precision and time needed for CADing and machining the the 3-lobed plates to match needed locations & size acccuraies for axle bearings and planetary gear shafts etc well enough for decent function and durability.
Instead we settled for a four pair dual overlapping "cam-wheels" design pictured below. It performs as well at climbing as any of the ~40 bots we have seen here in Illinois so far at league and qualifier competitions. We will be scoring all 160 mountain points most of the time in a couple more weeks, and we may be hitting the 2nd mountain zone in autonomous by then too. Our goal is for our bot alone to contribute 200 points to our aliance effort once we tune our autonomous efforts.
Practice run:
https://www.youtube.com/watch?v=tsOTYCp9CJM
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 21-12-2015, 17:21
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I haven't seen it in action, but I know that 5943 had a triwheel design. I'd pm Evan Hochstein about it if he doesn't pop up in this thread on his own.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 21-12-2015, 18:07
Enginerd
FTC #11722
Practice run:
Yeah, I've seen your split wheel design, looks impressive. However, I did see that your wheels stick on upper-mid bars. Did you sort out that problem?
We are rookie team and don't have much to start with. Definitely no CNC for us . It does look like even veteran teams are struggling with this season game.
Unread 21-12-2015, 23:25
AKA: Dick Ledford
These wheels were not that difficult to make, or that expensive either. We may even still try and improve on this design too.
Even though the curve transition from flat to round was was enlarged to improve shape for better corner release from under the churros as wheels go past them, they still will get somewhat stuck, depending on how well they are. or aren't, kept laterally in sync, but we can always re-sync them on the fly well enough to un-stick them and resume climbing. In autonomous, monitoring the sync status and making sync adjustments may prove too difficult though.
In teleop we always seem to quickly get high enough to place our dual winch hooks with our single joint swing arm though.
-Dick Ledford
Unread 22-12-2015, 10:09
Enginerd
FTC #11722
Any helpful information is much appreciated
Unread 27-12-2015, 13:14
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Here are a couple of photos of the 5943 design - we're using a Lazy Susan from mcmaster to allow independent rotation. This is from our current version - we're redesigning the robot currently with a Slewing Ring Bearing instead of the plastic lazy susan. The design works great, however there are some inconsistencies in how we attached the lazy susans and the plastic lazy susans have a "wiggle" in them that causes our chain to skip.
You can download and see our full CAD model on GrabCAD.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 28-12-2015, 21:56
Enginerd
FTC #11722
It looks like you do drive tri-wheel assembly as well as wheels; which what we I am thinking. Our design is a bit simpler though. I hope we can finish prototype very soon (we are still waiting for some parts. see this thread for details)
How well does your robot with tri-wheel climb and how high? also seeing that you are using omni wheels, I assume you don't have problems with turning on the floor?
Unread 30-12-2015, 14:38
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
I can't wait to see what you guys have come up with!
We got our robot to climb to the mid-zone once during practice with one of our prototypes. At that point, we were using 3D Printed custom sprockets and we sheared about 30% of the teeth off. Since that point we've encountered a lot of issues with the lazy susan we were using. That's why we are switching to the new bearing system that can be seen in the partner space on our GrabCAD account, see V4 of the design. https://workbench.grabcad.com/workbe...fUCrtD7FVlg031
One new item to note, is we removed powered front wheels. We have an idea of how to bring it back but right now the plan is to have that completely removed as it didn't add too much benefit.
Unread 30-12-2015, 15:05
Enginerd
FTC #11722
I also would like to see your design in action. Video would be nice
So, am I understanding correctly that you are planning to remove omni-wheels, so your tri-wheel assembly becomes 3-point star wheel? or you just removing power drive to wheels and they will be free spinning?
We are still waiting for parts from Pitsco since December 5. One of the thing we are waiting to finish this design is a worm gear box to drive tri-wheel assembly.
Unread 30-12-2015, 16:11
Enginerd
FTC #11722
Looking at your CAD design, wanted to ask you, where do you get sliders?
Unread 10-01-2016, 01:52
Enginerd
FTC #11722
As promised. Here are pictures of our tri-wheel design. That was this morning. It has been taken apart now :S
It showed a lot of promise, however even with 4:1 worm drive powered by AM motor wasn't enough to power this assembly.
