Go to Post Ban the ingredients for cheesecake, and stores will find substitutes. Remove the market for them, and stores have no reason to make them. - Rachel Lim [more]
Unread 28-12-2015, 15:56
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
pic: Chain and Wheel in Tube
Unread 28-12-2015, 15:57
FRC #1836 (MilkenKnights)
Re: pic: Chain and Wheel in Tube
It looks like you could make the outer wheels dead axles, which would make it easier to manufacture.
Unread 28-12-2015, 17:15
Flywheel Police
I'm curious, what makes a dead axle easier to machine?
Unread 28-12-2015, 17:22
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Holes for bolts don't require the same tight tolerances that bearing holes do, would be the main thing I could think of. But if you're doing a full tube thing like this, it would seem to me to be quite likely you have some sort of CNC capability, which makes that less of a factor.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Bolt sprocket to wheel. Stick big bolt through spacer, sprocket/wheel/bearing setup, apply locknut/jamnut/other locking fastener. Done. (Or, use a length of steel rod from McMaster, thread the ends with a die or drill for a cotterpin. Still a minimum-machining job.)
A live axle requires a keyway/hex feature and some sort of retention for the wheel/sprocket separate fro each other.
Unread 28-12-2015, 17:53
Flywheel Police
Cool. Good to know. Do you not lose those advantages with this being exact C2C chain in tube though? I'd imagine you need those tolerances to be high still so going to a dead axle doesn't really help in this case does it?
I'm a Software Engineer not a Mechanical Engineer so these are serious questions.
Unread 28-12-2015, 17:57
The exact center-to-center can actually be easier--the main thing is that your precision work is all on the tube, and it's a smaller hole so it can be easier to get right. I'd be willing to bet that it's possible to place and drill a dead-axle hole by hand--and drill it straight, too, with the right tools!--or drill press by someone who knew what they were doing.
There's also the option of throwing a tensioner block into the system, probably an off-center mounted delrin cylinder, but that kind of defeats the purpose of "ease of maintenance".
Unread 28-12-2015, 18:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As the tube constrains the chain, there is a much greater tolerance for chain slack. You may get backlash, but if the tube fit is tight enough, the chain can't come off the sprocket unless it breaks.
Unread 28-12-2015, 23:44
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
To be quite honest, that doesn't make the machining any easier.. The way my team does it, which is not the best way to do it but is perfectly fine for FRC requires the same amount of machining. In 2014 we were able to do a c-c belt drive train on a manual mill with no issue. It used the same bearing setup as shown in this picture. Either way, it would be a bit on the mill properly spaced the correct distance from the last hole. We use a 1.125" mill bit to drill bearing holes and have had no issue with tolerance thus far, we do not us a CNC.
Unread 29-12-2015, 02:47
Sounds like you have a pretty solid way to get the C-C. I'd suggest live axle in that case, since you'll constrain the bearings better. If you go with a dead axle, one of the design considerations is keeping the chain tight. If you tap the end of a shaft, your c-c won't be all that accurate because the clearance around the bolt in the frame adds a lot of play and potential for motion under impacts.
Unread 29-12-2015, 02:58
Cash4587's Avatar
AKA: Cooper Cash
We have a mill with a digital read out it's pretty useful. I think the best thing about c-c drivetrains is the fact that you don't have to mill slots for bearing blocks. However, with all of the new vex/wcp parts now pretty widely available, adding tensioning cams to the drivetrain only requires one more hole drilled in the tube. the WCP bearing blocks are huge time savers.
Unread 29-12-2015, 03:02
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
PREACH! The slots for a WCD are the worst part, and due to the inexperience of student machinist there are usually errors every year (except this one!) so going C-C also saves time in my opinion.
Unread 29-12-2015, 07:49
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
Inside a 2" tall x 1/8" wall extrusion, this kind of chain retention only happens when using 17t sprockets. 2363 uses 16t sprockets. There are different reasons why our chains don't come off the sprockets.
Unread 29-12-2015, 08:07
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
My point was not that all chain-in-tube has close-fit sprockets (the one pictured in OP is not), but that this technique could be exploited with a dead axle to make even "tape measure and drill press" tolerances feasible.
Unread 29-12-2015, 08:10
Chris is me's Avatar
AKA: Pinecone
Nothing about a dead axle drivetrain lowers the position tolerance requirement for an exact-center drivetrain at all. I have no idea what you're talking about here. You need more precision than that regardless of whether or not your axle spins.
