Go to Post You all are brilliant people. - Andy Baker [more]
Unread 28-12-2015, 17:53
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Chain and Wheel in Tube
Bolt sprocket to wheel. Stick big bolt through spacer, sprocket/wheel/bearing setup, apply locknut/jamnut/other locking fastener. Done. (Or, use a length of steel rod from McMaster, thread the ends with a die or drill for a cotterpin. Still a minimum-machining job.)
A live axle requires a keyway/hex feature and some sort of retention for the wheel/sprocket separate fro each other.
Cool. Good to know. Do you not lose those advantages with this being exact C2C chain in tube though? I'd imagine you need those tolerances to be high still so going to a dead axle doesn't really help in this case does it?
I'm a Software Engineer not a Mechanical Engineer so these are serious questions.
