Go to Post How come the dropped tool ALWAYS rolls under the exact center of the workbench? - DonRotolo [more]
Unread 29-12-2015, 14:49
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
"W" Drive Versa Wheels
We're buying wheels right now and I was curious if anybody has experience with the "W" treaded versawheels. They seem to have a nice bite into the carpet and turn well (no lateral 'bite') as well as a 1.2 CoF. Also, they're .3lbs and only $5 so I think we're going to buy quite a few. Just curious about what people have to say about them...
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 29-12-2015, 14:56
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: "W" Drive Versa Wheels
My second hand knowledge is that these wheels are known to wear quite fast, but I think that knowledge is from a year or two ago, so YMMV.
Unread 29-12-2015, 15:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
We used these wheels in 2013 and 2014, and were generally quite pleased. They have excellent traction, both in the forwards and lateral directions. When new, they almost act like cleats in the carpet.
The one thing to be aware of is that they wear rather quickly. Worn wheels do have both reduced traction and a smaller radius. This isn't a big issue if you have the money to replace them periodically (once per competition at bare minimum, once per day would be even better) and a drivetrain design that allows your wheels to be replaced swiftly. If you have a dead axle drive train that requires significant effort to take apart, I would suggest a lower maintenance wheel (such as Colsons).
Unread 29-12-2015, 15:23
jkelleyrtp's Avatar
AKA: Jon Kelley
http://upurs.us/image/47366.jpeg
Oh man I didn't think it would be that bad...
Is there a healthy medium between colsons and high traction wheels? Something around the 1.1 range maybe. I know andymark has a deal on plaction wheels for around $7.50. We'd like to stick with Vex but would rather something more aggressive than colsons.
Mechanical, CAD
Unread 29-12-2015, 15:24
headlight headlight is offline
headlight is an unknown quantity at this point
During aerial assist we replaced those wheels probably 3 times an event. We found that rotating them on the drive train helped too, the dropped wheel set tends to wear faster.
Unread 29-12-2015, 15:32
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Give the colsons a chance. The traction is suprisgnly good.
We had a similar experience with plaction as others did with W tread in 2014. The year was a bit of an outlier in terms of tread wear.
2016: FRC 865 Mentor
Unread 29-12-2015, 15:36
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
It's definitely worth mentioning what kind of tread you were using on the plaction wheels-- wedgetop, roughtop, blue nitrile, pebbled, etc all have different wear characteristics and CoF.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 29-12-2015, 15:53
mman1506's Avatar
no team (WARP7)
We we're using blue nitrile roughtop(usually considered the most wear resistant) but my point is that tread that could of last a whole season in 2012, 2011,2010 etc may last a couple of matches in 2014.
Unread 30-12-2015, 23:04
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
We have used them since 2014 and are inclined to use them again if they suit the game. In 2014 we replaced them about once per competition. In 2015 we ran the same set all season.
They don't get meaningfully smaller as they wear, but the sharp edges get rounded off and the CoF drops, requiring replacement (if you want to do well in a shoving match). We found that the tread tips on the corner wheels (8WD) wore in a "sawtooth" pattern, so we would swap them out end-for-end to stretch a few more matches out of the set.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at Standish and West MI in 2016)
FTC 6043 & 7911 (Competing at West MI and Allendale in 2015)
Unread 31-12-2015, 04:19
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
We did this to Colsons in 2014. Nasty, nasty traction. The individual segments flex and literally bite the carpet under load. They do wear faster than unmodified Colsons, but our robot played four events on the same wheels, and probably could have done another. All we did was rotate out the middle wheels to the ends after the second event.
We used the W tread wheels when they came out in 2013, and likely won't do so again. They wore quickly, and we also found their traction somewhat underwhelming.
Unread 31-12-2015, 06:07
AmiableVariable's Avatar
AmiableVariable AmiableVariable is offline
the ginger one
AKA: Hannah Fritsch
FRC #4488 (Shockwave)
AmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to all
We used those on our 2014 robot, as the dropped center wheels on a west coast drive, with a different, non-W tread set (same brand) on the front and back wheels. They worked pretty well, though we replaced them at least once per competition. We did manage to melt holes in the wheels during Galileo finals , but I think those were the outer wheels. Either way it's a good idea to be prepared to replace them.
Overall, we were pretty satisfied with how they worked.
Unread 31-12-2015, 12:16
jkelleyrtp's Avatar
AKA: Jon Kelley
Thanks for all the response so far... Has anybody used this before? They look similar to the diamond tread but have a 1.1 CoF. We'll probably go down the colson route but I just want to verify all the options right now.
Mechanical, CAD
Unread 01-01-2016, 12:16
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
What we love about the W tread wheels is their lower lateral COF and crazy high COF in the direction of travel. This results in a robot that requires less power to turn because of lower scrub forces. Less scrub likely means more accurate turns as well. This is our go-to wheel. Wear hasn't been as big a problem for us but being able to change them out for each competition would be wise.
Unread 02-01-2016, 11:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I disagree on the bolded. In 2014, we noticed a difference in the distance we drove in autonomous on worn wheels compared to fresh ones (and our wear isn't as significant as what was shown in some pictures). The radius change is definitely a relevant concern as the wheels wear.
Unread 02-01-2016, 12:47
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We've used the wheels, but we went with the roughtop tread option instead of the traction tires. Been using them for 2 years now with no complaints, still haven't found a robot our 2014 bot could not push.
