Go to Post Y'know... I think I'd much rather have big balls than hang myself... - FotoPlasma [more]
Unread 12-27-2015, 05:47 PM
klink135's Avatar
klink135 klink135 is offline
The one dat pushes da buttons
AKA: Max Jorgensen
FRC #5050 (Cow Town Robotics)
Rookie Year: 2015
klink135 is an unknown quantity at this point
Question Roborio/Arduino communication via DIO
Hi. Our team for the preseason is trying to use an arduino to control leds based on what buttons we press on the remote. I read somewhere that some teams do this through DIOs on the roborio to arduino. How would I code this in Labview? What do I need to code on the Arduino to make it work?
Unread 12-27-2015, 06:37 PM
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Roborio/Arduino communication via DIO
You would write to digital outputs in LabVIEW on the roboRIO and then read them in using digital inputs on the Arduino. The more DIO pins you relegate for this task, the more distinct color states you can choose (2^n different states).
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 12-28-2015, 07:39 PM
headlight headlight is offline
headlight is an unknown quantity at this point
You might be able to use a DIO to output a PWM signal, then read that signal with the arduino. (Or if you can spare a PWM port, you could use that). This would give you many more options for colors without tying up a bunch of outputs.
Here is some code to read PWM with the arduino (I haven't tried it, but I have done something similar with an adruino). https://gist.github.com/ivarvong/8202180
For the labview code you can probably use Pulse.vi. (Page 22-4 in this document, the newer version of labview should have an equivalent vi: http://www.ni.com/pdf/manuals/372668d.pdf).
Unread 12-29-2015, 04:54 PM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
i would suggest using i2c to talk to the Arduino This is what we did last year and it worked great. The other great things about this is you will not use up your DIO on the roborio and you can have a lot more features.
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
