Go to Post If you do mentor FIRST, be an asset to your team, but know that your students will admire you all the more if you set an example and finish your own homework. - Eugenia Gabrielov [more]
Unread 30-12-2015, 14:38
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: [FTC]: Tri-Wheel design
Originally Posted by ArtemusMaximus View Post
It looks like you do drive tri-wheel assembly as well as wheels; which what we I am thinking. Our design is a bit simpler though. I hope we can finish prototype very soon
How well does your robot with tri-wheel climb and how high? also seeing that you are using omni wheels, I assume you don't have problems with turning on the floor?
I can't wait to see what you guys have come up with!
We got our robot to climb to the mid-zone once during practice with one of our prototypes. At that point, we were using 3D Printed custom sprockets and we sheared about 30% of the teeth off. Since that point we've encountered a lot of issues with the lazy susan we were using. That's why we are switching to the new bearing system that can be seen in the partner space on our GrabCAD account, see V4 of the design. https://workbench.grabcad.com/workbe...fUCrtD7FVlg031
One new item to note, is we removed powered front wheels. We have an idea of how to bring it back but right now the plan is to have that completely removed as it didn't add too much benefit.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
