Valid Configuration? Kiwi with mechanum wheels
I've been going through a thought experiment for a while of a new holonomic style.
In the classic kiwi setup, the front two omni wheels are angled inwards like this with the goal of resolving movement vectors in x,y,ω. I have experience with this kind of robot but none with mechanum wheels. I think that mechanum wheels drive similarly to 4 wheel holonimic systems but will only move in the left in right directions if the forward component vectors are eliminated. So the goal would be to replace the front two wheels in kiwi with forward facing mechanum wheels like so: ![]() Here is my very poorly done vector diagrams of what I think will happen. I do realize that the angle of the rollers on the mechanum wheels will change the component vectors and have to be addressed in chassis shape, but for now I'm only looking for feedback on the idea. |
Re: Valid Configuration? Kiwi with mechanum wheels
See this thread for comments on a drive of this type.
One of the curious things that came out of my q&d analysis was that this can travel much more effectively to the left/right (that is, parallel to the axes of the mecanum wheels) than forward/reverse (parallel to the axis of the omni). More tonight. |
This idea will work fine, but why do it? The only thing I can think of is you save the money on one wheel, gearbox, and motor. I can't think of any other benefits. Some negatives are less driving power and less ground contact. A drive like this without actuation will make going over obstacles very hard. If you do want to do this, I would take a look at 1114's notes from this year on how to do a good kiwi drive.
![]() In a system like this, you would only need to force down the rear omni to put yourself on the appropriate strafe wheels. The forward mechanums would be off the ground just a tiny bit and chained to each side's gearbox. Therefore you would only need to add one motor, omni, and piston (or one versadrop) and have a butterfly style drive as opposed to this. |
Would the mecanums have to be off the ground? If they're chained to the traction wheels and the same diameter (as appears in the render), would they not be moving the same speed? Or is there another reason for them to not be touching that I'm just missing?
#7
The vectors don't resolve the same way meaning you couldn't have a perfect left-right strafe. It would be more circular movements, similar to H drive with only the front wheels touching. |
#9
I do see the advantages over normal kiwi drive, but I don't really see them over mecanum. And if you want to do octocanum, I feel like it would be easier to do it the usual way. |
#10
This is certainly a "boutique" configuration, only useful for a limited set of design requirements. I'll leave out the "articulated" version except to say that I'd be more comfortable articulating all three holonomic wheels rather than just the omni. If I did articulated, I might also consider doing some sort of PTO manipulator with the omni wheel to optimize motor use. Here are some of the design requirements this would meet:
If you do decide to build a robot to this design, the inverse kinematics are the same as for kiwi, except that the angle for the two wheels not on a coordinate axis are 45 degrees rather than 30/60. Ideally, you'd want to have the center of gravity along the axis of the omni wheel, trailing the axes of the mecanum wheels internally by 45 degrees, and the same distance from each wheel's contact patch. For this, we can adjust the inverse kinematics from Ether's kiwi paper, adjusting an angle, and letting the omni be wheel 1. Quote:
#12
To obtain a "pure strafe", the wheels at the top of the image would have to apply torque with out actually rotating. It can be done, but it would not just be standard FRC hook up of controllers, motors, gearboxes, and wheels.
#13
