Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Unread 30-12-2015, 17:29
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Valid Configuration? Kiwi with mechanum wheels
This idea will work fine, but why do it? The only thing I can think of is you save the money on one wheel, gearbox, and motor. I can't think of any other benefits. Some negatives are less driving power and less ground contact. A drive like this without actuation will make going over obstacles very hard. If you do want to do this, I would take a look at 1114's notes from this year on how to do a good kiwi drive.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 30-12-2015, 17:40
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
It wouldn't be its own drive system, but a dead simple way to do "ocatocanum kiwi."
In a system like this, you would only need to force down the rear omni to put yourself on the appropriate strafe wheels. The forward mechanums would be off the ground just a tiny bit and chained to each side's gearbox.
Therefore you would only need to add one motor, omni, and piston (or one versadrop) and have a butterfly style drive as opposed to this.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 30-12-2015, 18:03
DanielPlotas DanielPlotas is online now
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
Originally Posted by jkelleyrtp View Post
The forward mecanums would be off the ground just a tiny bit and chained to each side's gearbox.
Would the mecanums have to be off the ground? If they're chained to the traction wheels and the same diameter (as appears in the render), would they not be moving the same speed? Or is there another reason for them to not be touching that I'm just missing?
Sleep? What is that? A rare Pokemon?
Unread 30-12-2015, 18:10
jkelleyrtp's Avatar
AKA: Jon Kelley
More in an effort to consolidate traction than anything else. If you place them close enough to another traction wheel though, it shouldn't impact your pushing performance.
Originally Posted by z_beeblebrox View Post
Why couldn't you just use 3 omni wheels instead? You still have 3 DoF movement without the complexity/ weight/ size/ cost of the mecanum wheels.
The vectors don't resolve the same way meaning you couldn't have a perfect left-right strafe. It would be more circular movements, similar to H drive with only the front wheels touching.
Mechanical, CAD
Unread 30-12-2015, 19:54
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Why not? In this force diagram(not to scale), the torques from the front wheels cancel the torque from the back one. The center wheel creates a sideways force while the fore-aft forces from the front wheels cancel.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 30-12-2015, 21:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
To obtain a "pure strafe", the wheels at the top of the image would have to apply torque with out actually rotating. It can be done, but it would not just be standard FRC hook up of controllers, motors, gearboxes, and wheels.
Unread 30-12-2015, 21:40
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
This year 1658 used a similar drivetrain design, except with them having two rear omni wheels for strafing instead of one, and they had the strafe wheels on the front of their bot. A video explaining the drivetrain is here.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Custom User Title
AKA: Cal
Unread 30-12-2015, 19:37
Ari423's Avatar
FRC #5987 (Galaxia)
I'm not sure that will be as easy or work as well as you want it to. To get the traction wheels off the ground while keeping the mecanums on the ground, the mecanums will need to be on the front corners of the robot. If you leave them there, they are exposed to being damaged by anything you drive into. If you build an extended front perimeter, it will take time to design and build the front perimeter. At that point, you might be cutting off your nose to spite your face.
I do see the advantages over normal kiwi drive, but I don't really see them over mecanum. And if you want to do octocanum, I feel like it would be easier to do it the usual way.
2013: Programmer
Unread 30-12-2015, 20:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
This is certainly a "boutique" configuration, only useful for a limited set of design requirements. I'll leave out the "articulated" version except to say that I'd be more comfortable articulating all three holonomic wheels rather than just the omni. If I did articulated, I might also consider doing some sort of PTO manipulator with the omni wheel to optimize motor use. Here are some of the design requirements this would meet:
  1. You require being able to drive in ay direction, even if it means giving up traction. This either means that you think defense wil be light, or that you will be fast enough to get around it.
  2. You would rather have only three drive systems (otherwise you'd do mecanum or octanum).
  3. You require a rectangular chassis, either because of your technical limitations, or because of constraints imposed by the game and/or your game strategy.
Recycle Rush is probably the only FRC game so far where teams were likely to meet enough of these criteria to want to do this. The large rectangular game pieces and the lack of interaction with opposing robots could easily meet two of these requirements.
If you do decide to build a robot to this design, the inverse kinematics are the same as for kiwi, except that the angle for the two wheels not on a coordinate axis are 45 degrees rather than 30/60. Ideally, you'd want to have the center of gravity along the axis of the omni wheel, trailing the axes of the mecanum wheels internally by 45 degrees, and the same distance from each wheel's contact patch. For this, we can adjust the inverse kinematics from Ether's kiwi paper, adjusting an angle, and letting the omni be wheel 1.
Originally Posted by Ether's Kiwi inverse kinematics, adjusted for meckiwi (italics)
Xj, Yj, & Zj are the 3 joystick axes
  • forward = Yc = -Yj
  • strafe right = Xc = Xj
  • rotate clockwise = rw = Zj
  • wheel1 = Xj + Zj
  • wheel2 = -0.707 Xj + 0.707 Yj + Zj
  • wheel3 = -0.707 Xj - 0.707 Yj + Zj
Unread 30-12-2015, 17:42
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Another reason could be ease of building. At least to me, it seems a lot easier to build (and less errors possible) with only having to work with 90 degree angles instead of 60 degree angles. Also, you take advantage of a rectangular frame instead of a triangular frame to build off of, which is nice in games where you have to fit into a certain space instead of having a set perimeter size restriction.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
