Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 31-12-2015, 05:51
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: pic: Inverted CIM Gearbox V3
Originally Posted by asid61 View Post
A possible fix for the cantilever gear would be to have a bearing in the gear riding on a "dead axle"- a screw with a spacer on it going into a tapped plate.
That wouldn't fix the fact that it is still cantilevered. There would need to be a supporting plate on the other side of the gear to reduce the kinds of loads a cantilevered gear sees vs a non cantilevered one.
Unread 31-12-2015, 13:19
Aren Siekmeier's Avatar
on walkabout
It would reduce the torsional load on the bearing to nearly zero. A dead shaft rigidly mounted to the gearbox plate can handle high loads that are cantilevered half an inch or less. The bearing moves to the same plane as the gear, much like the gears engaged by the dog/balls in the shifting stage.
