pic: 1540's new 3 cim dog shifting gearbox
Re: pic: 1540's new 3 cim dog shifting gearbox
Looks good, reminds me of some of the low-profile shifters I've seen on here.
The way you've done the lightening pattern seems nontraditional. I think if you added a few more struts you could greatly increase the strength of the gearbox. What cylinder are you using to shift? That low speed seems fine for 3 CIMs, but do you have a plan for if you brown out? EDIT: Are the gearbox plates flippable? Interesting, I haven't seen that feature before. Last edited by asid61 : 01-01-2016 at 18:15. |
How are you planning on attaching the gearbox to a chassis?
Looks good. Obligatory warning: The roborio is at risk if browning out from the current load and subsequent voltage drop of a 6 CIM drive train.
We ran bolts through the tubed took of our frame and then through the bottom 4 standoffs of the transmission. While this cantilevered the gearbox a bit, we found that with 4 bolts, that attachment technique worked just fine on one of our off season robots.
The gearbox plates are flipable. We used .5 inch stroke, .75 inch diameter bimba button cylinders for shifting. As for brownouts, we found that they only occurred when we were in high gear and we plan to add software base current limiting in the future to account for this. Last edited by Adolfo Apolloni : 01-01-2016 at 20:28. |
Why did your team decide that this is necessary? If the flipable gearbox plates is not a requirement, you can save material and space by cutting out or lightening the corner of the gearbox that doesn't have a shaft in it.
#7
Under what types of testing scenarios? How much did the robot weigh/battery condition?
#8
As for the flipable plates, we kept the section in the bottom corner so we had the ability to add a power takeoff if we wanted to later. It is an inconvenient spot for a power takeoff as it is on the bottom of the gearbox but we thought is was better than nothing. Here is a link to a step file of the gearbox. https://drive.google.com/file/d/0B40...ew?usp=sharing Last edited by Adolfo Apolloni : 02-01-2016 at 01:21. |
#9
I don't know exactly how much current the other mechanisms drew but we did have a football shooter driven by 2 cims and a football intake that was driven by a bag motor on that robot
