Go to Post What is this "tired" of which you speak? Did it come in the KOP? - EricH [more]
Unread 01-01-2016, 21:18
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: ABS-114, supercompact planetary PTO shifter
Unread 01-01-2016, 21:20
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: ABS-114, supercompact planetary PTO shifter
What is this, I don't even...
I hope you'll consider posting the CAD for this at some point, I'm having a hard time even grasping how this thing works. It certainly looks/sounds impressive though!
Unread 01-01-2016, 22:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That's a lot going on in a little space; very impressive, especially if it works.
The CAD or at least a few renders from other angles would be helpful to understand it all, but let's see how much I can get it from the one render:
  • Is there a second pancake (or other) cylinder hiding under those CIMs, probably coaxial with the drive shaft that accomplishes the drive train shifing, or is the cylinder on top some sort of 3-state device?
  • Where is the PTO output located? I understand it's linked to the ring gear, so the most obvious place would be behind the drive shaft, where I thought the shifting cylinder would be located. Doing this would not only move the shifter out of the obvious place, but it would be difficult to pass all the different coaxial shafts through the large gear, so I'm guessing that the annular gear has teeth on both the inside and outside of the annulus, and the PTO is another spur gear that takes off of that. Doing bevels would require a lot of extra work and thrust bearings for no discernible benefit.
  • If I understand this right, the PTO output would have to have the shifter in high speed/low torque (single stage) mode, and the carrier is locked, so the output gear ratio would be (64 / 11) * (72 / 30) = 14.0:1 at the ring gear, possibly higher or lower if the PTO is not directly taken from the ring gear.
Unread 01-01-2016, 22:35
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
This is incredible... After half an hour of looking at ABS-111 (the latest one I can find online) and googling planetary gear ratios, I think I sort of understand now. Time for questions:
  • which one is the carrier plate?
  • how do you lock the ring gear/carrier plate? I'm assuming there's a custom piece of metal the render is hiding... I want to see it.
  • checking my understanding: so there is a "suicide mode" (high gear/PTO) where the carrier plate is linked to the input but the carrier plate is locked?
  • consider using Andymark's new CIMcoder? I hear that it's thinner than the 3D printed one
  • how does one machine their own ballshifter? (looking at ABS-111)
  • Is that 60t gear hitting the bolt next to it?
  • how close are the CIM gears to hitting the gearbox plate?
  • that's a cool way to attach something normal to a gearbox. I might steal one one day.
  • what are those 6 holes near the output for? I assume 2 is for mounting a piston on the other side, but 6?
Originally Posted by GeeTwo View Post
[*]Where is the PTO output located? I understand it's linked to the ring gear, so the most obvious place would be behind the drive shaft, where I thought the shifting cylinder would be located. Doing this would not only move the shifter out of the obvious place, but it would be difficult to pass all the different coaxial shafts through the large gear, so I'm guessing that the annular gear has teeth on both the inside and outside of the annulus, and the PTO is another spur gear that takes off of that. Doing bevels would require a lot of extra work and thrust bearings for no discernible benefit.[*]If I understand this right, the PTO output would have to have the shifter in high speed/low torque (single stage) mode, and the carrier is locked, so the output gear ratio would be (64 / 11) * (72 / 30) = 14.0:1 at the ring gear, possibly higher or lower if the PTO is not directly taken from the ring gear.[/list]
I think the PTO is the front-most gear we can see, and it's connected to the gear on the left, which would mean that the PTO shaft is to the left of the 2nd pancake piston. Looking at the 2 PTO gears it actually look like there is some sort of reverse-reduction there. This is all conjecture though, until we get more renders/CAD.
Edit: can we at least get a render of the internals?
Last edited by Chak : 02-01-2016 at 00:24. Reason: strikethorugh-ed the nonsense, added more questions
Unread 01-01-2016, 22:49
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
You know, you only need one CIMcoder.
The new AM Cim moter encoder is thinner than the original CIMcoder however it is twice the costs and you reclaim only ~.25" of shaft. Plus the original CIMcoder is designed for an extremely robust encoder with programmable resolution. Of course I am a little biased towards my own design.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 01-01-2016, 23:32
AdamHeard's Avatar
Lead Mentor
That's not a fair comparison as yours doesn't factor in labor cost.
Unread 01-01-2016, 23:41
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I only see two gears, the 11-tooth pinion of the near CIM and the 60-tooth gear it engages. The two structures behind the front plate do not look like gears; the spacing between "teeth" is uneven, and the tooth profile doesn't make sense for gears.
I also don't see a second pancake piston; are you assuming it's below the CIMs coaxial with the 60-tooth gear?
What 2 PTO gears?
Unread 02-01-2016, 00:08
AKA: Thomas
Team Role: CAD
What 2 PTO gears?
ohhhh I see now. What I assumed to be a gear for the PTO, the thing right behind the front plate, is the carrier plate (answers one of my questions). What I assumed was "gear teeth" now look like the geometry that locks the carrier plate when the piston pushed down. Everything I said earlier is nonsense then . My revised guess is that the PTO is the piece of metal connected to the ring gear with a 1.875'' bolt circle on it, connected to nothing yet.
Yes, I'm assuming that there is a second piston there based on ABS-111, the closest iteration of this I can find online, plus I can't think of a way that the top piston can possibly reach and engage the sun gear even with a third state. Edit: Also, the holes in the gearbox plate near the output, assuming identical gearbox plates, suggest a mount for the Vexpro pancake piston.
Last edited by Chak : 02-01-2016 at 00:26. Reason: found another reason there might be a 2nd piston hidden in the render
Unread 02-01-2016, 13:25
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Looks very impressive. Please post cad files - thank you.
Unread 02-01-2016, 15:15
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I forgot to update the Partner Space recently it looks like. I just finished, so you can take a look at the CAD here. As a side note, ABS-110 (the PTO shifter with the 3-position cylinder) is 0.7lbs lighter than this and far easier to machine. It's also about as compact. The only disadvantage it has compared to this one is the lower spread; 2.3 versus 3.4.
Yes, there is another Vex pancake cylinder underneath the CIMs.
The PTO output is a 32 tooth #25 sprocket that sits in between the 60t gear and the ring gear. It is linked to the ring gear via an aluminum hub/plate. Only one shaft; no double-tooth things involved. None of the gear teeth have to be machined fortunately.
That's right, the carrier is locked and the sun gear is engaged to make the PTO work.
The carrier plate is the frontmost aluminum plate, in front of the brown steel ring gear.
The odd tooth-looking dealies on the carrier and ring engage with 1/4" steel pins with rounded ends to lock them. The cylinder simultaneously disengages/engages at the same time.
There is indeed a "suicide mode". Hopefully one would check to make sure the code is working right before activating that endgame mechanism.
Oddly enough, the 3D printed version is better because I actually want less CIM shaft protruding out. It can intersect with the PTO chain if it's too long. I have the second one to act as a spacer.
Usually it's very tricky to machine, but this one is easier than most. Start with a rod, turn down the outside dimensions leaving 13.74mm for thunderhex, bore out the cylinder for the ball part, drill through with a 1/4" drill bit. Then take it over to the mill, stick it on a dividing head, drill the 6 ball holes and mill down the hex. The gears you just stick on a fixture and CNC.
The linkage thingy between the shifting cylinder and the shifting rod is something of my own design, utilizing a 3/8"-16 outer 10-32 inner threaded insert and a couple bearings. Very easy to machine and more compact then the Vex option.
Yes, that bolt is. Good catch, I must have moved something. I just replaced it with a countersunk screw so it no longer touches.
The CIM gears are about 0.6" in diameter, and the hole in the plate to accept the CIM is 0.75", so no danger there.
Thank you, I liked it too.
2 for mounting the cylinder, 4 for mounting. This has a couple options for mounting; you can use the bottom 2 screws that keep the gearbox together or just the 4 holes in the front plate.
There is no real "PTO shaft"; there is a single shaft. The PTO output is attached to the ring gear, which is possible due to epicyclic (planetary)/differential gearing shenanigans.
I would try for an internal render, but the internals are rather convoluted so it's hard to get everything with one picture. Let me give it a try though.
Unread 02-01-2016, 17:38
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I hope I'm misreading this, but I can't figure out how to make sense of this. If the PTO output comes down the same shaft as the wheel drive, what makes the PTO mechanism move in one case but the wheels in the other?
Unread 02-01-2016, 18:33
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Whoops, I didn't mean it that way. The PTO output is a 32t #25 sprocket with a versakey. It is bolted to a plate that is bolted to the ring gear. The only interface it has with the main shaft is a bearing it rides on to keep it centered. Basically, the PTO output is a "dead axle" sprocket, not a shaft (which I dislike but is hard to work around).
Unread 02-01-2016, 23:32
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
So that thing that looks in the render like a round disk between the ring gear and the 64-tooth gear is actually a #25 sprocket? This would certainly be convenient in that PTO could be geared up or down by a factor of about 2 through selection of a PTO receptor sprocket.
Unread 03-01-2016, 00:07
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The round disk is a hub for the #25 sprocket, which is hidden behind it in the render. The GrabCAD model should clear it up.
You can use pretty much any sprocket with a versakey pattern as long as it's not large enough to hit the standoffs.
Unread 03-01-2016, 01:09
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
A #25 chain will fit between that disk and the 60t gear?
