Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 02-01-2016, 16:50
echin's Avatar
echin echin is offline
AKA: Eric Chin
FRC #3467 (Windham Windup)
echin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the rough
pic: Partial PTO Gearbox
Unread 02-01-2016, 16:56
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Partial PTO Gearbox
Interesting, could be handy for a lot of things.
I don't quite understand how the PTO shifting works. While in PTO mode, are all three motors engaged in DT and PTO? Do they have to move together or can you configure it so that they are separate?
What is the weight?
You may want to make your tapped standoffs hex so you can get a wrench on them.
Unread 02-01-2016, 17:02
EmileH's Avatar
EmileH EmileH is offline
uses the Talon SRX way too much
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Link to the CAD?
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 02-01-2016, 17:20
echin's Avatar
AKA: Eric Chin
In the current configuration, when in PTO mode, two motors are on the drive train and one is on the PTO, but it could be inverted easily. Since the PTO motor is not connected to the drive train when the PTO is engaged, it can be driven separately. When in the full drive train mode, all three motors are on the drive train.
The weight is slightly over 12 lbs with materials set correctly according to Inventor.
Here's a link to the CAD: https://workbench.grabcad.com/workbe...GLc2OPK4aS5nCL I haven't used GrabCAD partner spaces before, so let me know if it doesn't work.
FRC 3467 Chief Technology Officer (Co-Captain)
FTC 10251 Design Mentor
Unread 02-01-2016, 18:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
A neat idea, but the number of possible failure modes coordinating the shift is troublesome. To minimize both mechanical and electrical transients, I would probably want to put the PTO motor(s) in coast and dead band during the shift, and re-enable the PTO motor controllers after the shift is complete.
I've thought of alternate uses of this mechanism:
  • If you used two of these and linked the PTOs together, you could make a drive system that shifted from 2 3-CIM shafts to 3 2-CIM shafts, which might be useful for some articulated drive styles, such as a Nonadrive or a (just thought of this) "TanKiwi".
  • The concept (though probably not this implementation) could also be used to couple and decouple the forward and rear wheels for an octanum or decanum implementation.
Unread 02-01-2016, 19:00
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Wow, that's super handy then. You could use it for shooters or lifting things while still driving, which seems extraordinarily useful.
