Go to Post ...and then at the end they interviewed this 5 year old on his favorite part (of the fair): "I liked the robot" - Jessica Boucher [more]
Unread 02-01-2016, 19:47
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: pic: Vex Face Bearing Gusset Gearbox
Originally Posted by asid61 View Post
The largest reduction could even be 70:14 if you use 3/8" hex bore gears.
If there was a way to easily align these across a tube, like some kind of C-channel acting as a square, you could just make a gearbox with oversized holes made with a step drill and a piece of versaframe.
Originally Posted by s_forbes View Post
If you are going from a CIM, you can have a 12/72 reduction, or even an 11/72 reduction using vexpro's 11 tooth pinion gear (link).
The original design used 8mm to 1/2 adapters and was supported by a hex bearing and therefore required a hex bore gear. As Adam pointed out, using a bushing is a better idea and allows you to use CIM gears.
If you want a less aggressive first stage, you can still use the adapter and a hex bore gear.
