Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
Unread 02-01-2016, 18:25
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
pic: Vex Face Bearing Gusset Gearbox
Unread 02-01-2016, 18:27
AKA: -matto-
FRC #1410 (Kraken)
Re: pic: Vex Face Bearing Gusset Gearbox
STEP is here
Thanks asid61!
Unread 02-01-2016, 19:01
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
The gusseting looks a bit overkill to me. This is a cool Idea though.
Unread 02-01-2016, 19:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Originally Posted by aldaeron View Post
Trying to attach the STEP file and cannot seem to find the attach button I am looking for. Help please?
You can only attach certain formats, and even then only up to 2MB. Uploading to Drive or GrabCAD first helps. I recommend the latter because it has infinite file storage and revision control for free.
Looks pretty neat. What gusset does this use again? What size gears can you use?
Unread 02-01-2016, 19:26
AdamHeard's Avatar
Lead Mentor
1.125" OD x .75" ID bushings are available on mcmaster. I'm assuming the goal is to pilot the CIM in a 1.125" bore?
Unread 02-01-2016, 19:29
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Pretty clever! I'm hoping vexpro will come out with a transmission that attaches to a 1x2 tube in a similar fashion in the future. They have lots of cool gearboxes, but they don't seem to bolt on to tubular frames very easily.
Versaframe face gusset. Here's a drawing. Hole spacing is for 84 total teeth.
Unread 02-01-2016, 19:33
AKA: -matto-
FRC #1410 (Kraken)
I knew one of the many gearbox designers would know how to help. Added link to the STEP above.
It is the .090 sheet metal Vex Face Bearing Gusset. It is sized for 84 Tooth 20 DP gears (C-C is 2.103). Vex Drawing is here.
Basically you get two gear reduction pairs of any two hex bore 20 DP gears that add to 84 teeth. The largest reduction is 66:18 (3.67).
It may not be as reuseable as other gearboxes and does take some assembly work, but is an entry level way to get into custom gearbox design. I think you could stack two 6" pieces of VersaFrame and make a standalone gearbox if you want.
I haven't priced it (depends on your gear choices and if you go as crazy as I did with extra supporting gussets). My quick calc says as shown it is $50 plus the cost of the 5 gears (~$50), plus the mounting hardware, collars and shaft pieces. Not as cheap as the Vex Double Reduction at $60, but not bad for a custom gearbox with no CNC required IMO.
-matto-
Unread 02-01-2016, 19:35
AKA: -matto-
FRC #1410 (Kraken)
This is what happens when late night designing with "holiday cheer"
Should have thought of that!
Unread 02-01-2016, 19:39
s_forbes's Avatar
If you are going from a CIM, you can have a 12/72 reduction, or even an 11/72 reduction using vexpro's 11 tooth pinion gear (link).
Unread 02-01-2016, 19:41
Oblarg Oblarg is offline
AKA: Eli Barnett
I really like the easy chain access with this design. Clever.
"The breakfast of champions!"
Unread 02-01-2016, 19:44
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
-matto-
The largest reduction could even be 70:14 if you use 3/8" hex bore gears.
If there was a way to easily align these across a tube, like some kind of C-channel acting as a square, you could just make a gearbox with oversized holes made with a step drill and a piece of versaframe.
Unread 02-01-2016, 19:47
AKA: -matto-
FRC #1410 (Kraken)
The original design used 8mm to 1/2 adapters and was supported by a hex bearing and therefore required a hex bore gear. As Adam pointed out, using a bushing is a better idea and allows you to use CIM gears.
If you want a less aggressive first stage, you can still use the adapter and a hex bore gear.
Unread 02-01-2016, 20:09
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
It looks like the two pieces VersaFrame still need to be precision machined for the gears to mesh well. Am I wrong? If not, how is this any different from any other custom gearbox?
EDIT: How are the CIMs attached to the top piece of VersaFrame? There are holes through the gusset plates, but I don't see anything through the VF itself. Is the plan just to mount the CIMs to the gussets?
EDIT 2: Is there any reason why the first reduction has to also sum to 84 teeth, or can that be any gear ratio provided you use the right C2C distance?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 02-01-2016, 20:55
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Interesting idea. Have you done any price comparisons between using your method and using clamping gearboxes*?
*See the "gearing options" portion at the bottom of the page.
All the machining required on the versa frame for this can be done with a drill press or hand drill and a dremel. You can match drill all the gusset holes. Any slotting required for clearance for the first reduction gear can be done with a dremel, cutting wheel, and some patience. All the piloting is handled by the gussets and bearings, so no precision machining is required.
A total of 84 teeth (20DP) is the "right" C2C distance for the 2.103" spacing used by Vex for the gussets.
Unread 02-01-2016, 21:29
Ari423's Avatar
FRC #5987 (Galaxia)
I didn't realize you could use the gussets as a guide to drill the other holes. That's a smart idea!
I didn't see the double plates in there; I thought they were all single plates. Never mind then.
Overall, I really like this design! I might just suggest it to my team.
2013: Programmer
