Go to Post cue Dave Lavery with some witty response - Taylor [more]
Unread 02-01-2016, 17:32
first_newbie first_newbie is offline
FRC #1718
first_newbie is a jewel in the roughfirst_newbie is a jewel in the roughfirst_newbie is a jewel in the rough
6 CIM robo-rio brown out
Can someone please explain the issue with brownouts for 6 CIM motors with Robo-Rio?
Unread 02-01-2016, 17:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 6 CIM robo-rio brown out
Check out these two threads:
Brownout behavior - alternative design goals
How do you design a robot that doesn't brownout?
The issue isn't strictly limited to 6 CIM drivetrains, but to any system which draws enough current from the battery to bring the battery supply voltage (momentarily) below 6.3V. This is most likely to happen in a pushing match, and many (most?) 6 CIM drive trains designs are intended for pushing matches.
Edit: Another common cause for the brownout is running the robot for far more than three minutes without changing the battery. We haven't had this happen to us during competition, but it has happened several times during drive practice and at demos.
Unread 02-01-2016, 17:52
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
The high electrical draw of the CIMs such as when turning or accelerating or pushing can lower the overall system voltage, when it goes lower than a 6.8v the roborios inbuilt brownout protection system starts to cutoff things, until it finally turns off itself, meaning that the robot disconnects from the FMS and the driver station.
It is explained in detail here
http://wpilib.screenstepslive.com/s/...g-current-draw
Unread 02-01-2016, 19:36
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
The RoboRIO brown-outs at 6.8V. What does that translate to in Amps? Based on my limited high school physics knowledge, I think it depends on the battery's internal resistance, but is there a set number for that?
If not current, how else would we know the voltage drop caused by the current draw of a design? I see warnings about 3 CIM drivetrains everywhere, but is there a way to calculate/estimate the voltage drop and mathematically prove that 3 CIM drivetrains will brown-out? It would be interesting to see whether a 3 CIM drivetrain would work under certain situations, or if 3 CIM drivetrains are just not possible.
Unread 02-01-2016, 19:53
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I can't speak to the battery resistance part. I can say, however, that there's more to it than just 3 CIM motors. It also has to do with robot weight, track CoF, gear ratios in the drive gearboxes, lengths and size of wire between the battery and motors, and a bunch of other stuff.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 02-01-2016, 21:13
There's lots of good information in those threads and screensteps. Here's some more information.
In most cases, a brownout condition will turn off your motors for a fraction of a second, and then everything will recover. You may not even notice most brownouts.
The times that you're most likely to brownout is when accelerating from a stop, when turning, or when in a pushing match. Here's ways to reduce or eliminate brownouts.
1) Verify all electrical connections are tight. Loose electrical connections will increase current draw.
2) Verify smooth mechanical function. Binding or rubbing will cause more current draw.
3) Reduce long wire runs. Wire electrical resistance is proportional with length, and reducing wire length will reduce current draw.
4) Shift to low gear when pushing or turning
5) Reduce aggressiveness of commands to the drivetrain. This can be through driver practice, or through a filter or rate limiter implemented in software.
6) Increase wire size. Think about 4awg instead of 6awg for batteries, and 10awg instead of 12awg for your drive motors. If you have a drivetrain that draws 240amps, changing 2 feet of 6awg wire for 4awg wire will reduce voltage drop by about .2 volts, and 2 feet of 12 awg wire with 10awg will reduce voltage drop by about .1 volts.
7) Consider reducing power use in other areas. For example, adding air tanks might make it unnecessary to run the compressor.
8) Change gear ratios. Using a larger gear reduction will reduce current draw in all the scenarios above.
9) Reduce lateral traction (put wheels with less traction, or omni wheels on the corners). This will help with the turning case.
10) Reduce forward traction. This will help with the pushing case.
I'm sure I'm missing a few tips.
I've seen people suggest that removing 2 CIMs from a 6 CIM drive train will fix things. My guess is that a 6 CIM drivetrain that is consistently browning out will not be measurably helped by removing 2 CIMs. It will respond much more sluggishly. It will also significantly increase the chance of poping the 40 amp breakers, which will take seconds to recover from, rather then tenths of seconds from a brownout.
I did say that in most cases brownouts won't be noticeable. If a longer brownout occurs, and the power drops to about 6.2 volts, the roboRIO 5v rail will turn off. This removes power from sensors. Here are some specific cases where they will cause negative effects, and how to design around them:
1) A mechanism that uses a motor providing constant power to hold something. This could be pinching a ball, holding up an arm, or pulling back a spring for a launcher system. Adding a ratchet or a counterbalance will reduce the effect, if the motor turns off for a little bit.
2) For ratio-metric sensors, such as potentiometers, implement ratio-metric measurements using the voltage from the 5v power rail. The voltage is available in all three programming languages, and ratio-metric measurement is implemented in potentiometer class in all three languages. We did this with our 2014 robot and noticed very little disturbance in potentiometer readings when in brownout.
3) Replace incremental sensors with absolute sensors. For example, instead of an incremental encoder that you zero at the beginning of the match, use an absolute encoder such as the MA3.
4) For sensors that have some type of calibration routine on startup, power them from either the roboRIO USB port or VRM. Some examples are ultrasonic sensors and the NavX IMU. The NavX has additional information here: http://www.pdocs.kauailabs.com/navx-..._for_Brownouts
In all but the last case, if you're doing closed loop control, read the state of the 5v rail to determine if you can trust the value from sensor.
Here's some real world experience:
In 2014, we ran a 6 CIM drive train, 2 speed, with theoretical speeds of ~18 ft/s and 8 ft/s. We used 8 wheel drive with versawheels. We never blew the main breaker. We played plenty of defense towards the end of the season.
We used 10 awg wire on each of the drive motors, as well as kept the wires short (PDB was mounted very near the motors). We used 4 awg wire from the battery to the breaker and PDB, but used standard 6 awg on the battery. We did not implement any software magic, but the driver knew to shift to low when pushing.
We beta tested the roboRIO, and installed it on our practice robot in the fall of 2014. We competed with that robot at the 2014 SCRRF Fall Classic. We never noticed any problems due to brownout. We collected current during a match. See http://www.chiefdelphi.com/forums/sh...&postcount=153 The battery voltage shows that we browned out several times, but our drivers never reported any problems.
Several other teams with 6 CIM drivetrains also ran with the roboRIO during the beta. Several teams reported seeing brownouts, but only a few had real problems.
The important thing is to test your robot and see how it responds to a brownout. Like GeeTwo said, just run your robot on the same battery for long enough.
Last edited by Joe Ross : 02-01-2016 at 22:10. Reason: Indysam objects to the term pistons instead of cylinders, whereas I conflated tanks and cylinders.
Unread 02-01-2016, 21:14
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
That's pretty much the high-level story. 3-CIM-per-side drive trains are not, if managed properly, the kiss of death. With proper current and voltage monitoring, it is certainly possible for software to truly "brown" out the motors (by reducing the supply percentage or cutting off a motor) rather than "black" them all out at the same time as the RoboRIO shall do. This is a "black" out in that all of the PWM and CAN motor controllers are disabled at the same time; a brown out is when voltage is limited to prevent a black out. The "black out" prevented by the built-in "RoboRIO brown out" is only enough to prevent a RoboRIO shutdown and reboot. While I cannot tell you that it hs never happened, I do not know of this happening to a cRIO starting with a fresh, healthy battery in a 3-minute match.
The real question is whether, after writing "true brown out software" there is enough of an advantage to justify the weight, expense, and gears of 3-CIMs vs 2-CIMs per side.
Edit (ninja'd):
In our experience, you will definitely notice. This is what happens:
  1. The current draw causes the RIO to "brown out" the motors.
  2. The voltage recovers.
  3. The system restores the motors.
  4. The motors draw inrush current.
  5. Return to step 1.
This results in a very distinctive "stutter" at about 15-20 jitters per second that gets the robot nowhere fast.
Please don't construe this as disagreeing with any of Joe's mitigation strategies! (Well, in #7, I'd say tanks rather than cylinders. Are you reading, IndySam, Lil Lavery, and BBray_T1296?)
Unread 02-01-2016, 22:04
I don't disagree that this is what happens in the really badly wired / really badly geared / really old battery cases, but I don't think this is the normal case. Certainly, our robot didn't experience that in real competition (although did in extended pratice). Rather the robot gets started moving, browns out, and starts again, however since there is already motion, the inrush current is less and it breaks the loop.
Unread 02-01-2016, 22:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
In the interest of full disclosure, we encountered the "stutter" we encountered was experienced when running longer than 3 minutes, either in driver practice or at a demo. To the assertion that the behavior in the first 3 minutes is "it browns out, but by the time it comes back, its OK", I have to express a healthy dose of skepticism. If that's what actually happens, then the old truism "A difference that makes no difference is no difference" applies. I suspect that we'll end up simulating some pushing matches this year to find out for ourselves.
Unread 03-01-2016, 01:12
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
What would be a safe fps for a 120 pound robot with a 6 CIM drive train?
Unread 03-01-2016, 09:44
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
It depends on your driving conditions and what you mean by safe. If safe means that the chassis is traction limited so that it is all but impossible to draw more than 150A, total, you can use JVN's latest calculator to get the answer. I leave that as an exercise, but the answer will surely be "too slow to be competitive for most FRC games and strategies."
The real question with a 6 CIM vs a 4 CIM drivetrain is "How much more torque/power can I get when running current limited?" For sake of calculation, let's assume you have a 180A current budget for your CIMs in a relatively short battle. During this time period, each CIM in a 6 CIM drivetrain will draw 30A, and each in a 4 CIM dirivetrain will draw 45A.
Checking the CIM power curve, at 12V and 45A each CIM generates about .79 Nm of torque, and at 30A it's about .51 Nm, meaning that the 4 CIM drive train can actually generate about 0.1Nm more torque. The advantage is in power: the 2160W of electrical power consumed by each drive train is converted to mechanical energy about 7% better by 6 CIMs than 4, yielding another 160W of mechanical power.
If your mechanisms are fast enough and reliable enough and your driver good enough to make use of that power, go for it. If not, 6 CIMs just makes it a bit easier to draw too much current. The bottom line is that a 6 CIM drive train is inherently more dangerous than a 4 CIM drive train. You need to evaluate whether the danger you're causing is worth the danger you're accepting.
Unread 03-01-2016, 16:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
With 4 CIMs it seems easy enough to trip a 40 Amp breaker if the robot is geared high (fast) and pushing. But what if you ran 6 Mini-CIMs? Less chance of tripping a 40A breaker, and no concern about browning out. In theory, you could gear a robot with 6 Mini-CIMs higher (faster) than a robot with 4 CIMs. Thoughts?
Unread 03-01-2016, 21:59
Roboshant's Avatar
FRC #0226
Rookie Year: 2015
Would pushing with a high gear reduction (slow) do you still have a chance of browning out?
Unread 03-01-2016, 22:04
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The big snap action breakers are rated 40A. The main breaker is rated 120A. If you have four or more snap action breakers in roughly equal use, the main breaker and brown out are more likely to be an issue than an individual breaker. The advantage to having more small motors is that you are more likely running them nearer peak efficiency, and also spreading the waste heat around better.
Unread 03-01-2016, 22:24
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
You would think this is true, but take a look at the breaker curves. Let's say you have 4 CIMs going at 80 amps each. That's 200% rated current for the 40A breakers, so that's 1.5 to 3.9 seconds. The total is 320 amps, or 267% rated current for the 120A breaker, which is about 7 to 17 seconds. The 40A breakers should go first, assuming your drivetrain is the only thing running.
Does that match teams' real world observations?
Datasheets*:
http://files.andymark.com/PDFs/am-0282_data_sheet.pdf
http://files.andymark.com/MX5SpecSheet.pdf
*Presumably the datasheets for the 40 and 120A breakers on the Andymark website are accurate and up-to-date
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
