Go to Post A great mentor guides without giving the answers, teaches through discovery, demonstrates without lecturing, provides support from backstage, observes without hovering, and leads by example. - dlavery [more]
Unread 02-01-2016, 22:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: How to build good bumpers
Originally Posted by rich2202 View Post
One other tip on making a bumper:
If the minimum height is 4" off the ground, then make your bumper 5" to allow for sagging of the noodles.
How do you get an inch of noodle sag? We have never had as much as 1/4" of noodle sag, even before doing clamps and just pulling the fabric tight by hand.
IIRC, the more recent games (excepting 2015) have required bumpers to fit in the "bumper zone" between 2" and 10" above the floor. The bumpers are nominally 5" tall, giving 3" of design leeway. In 2014, when we were picking a big ball up over the bumpers, we went low. In 2013, when we did not have a frisbee pickup, we went a bit higher to reduce the chance of our bumpers and drive getting caught on a frisbee. IIRC, in 2012 (before I was directly involved on the team) we put the bumpers near the middle of the bumper zone as we intended to play defense. Unless you need to have 4+" of ground clearance, I don't know why you'd go to the top of the limits.
