Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 02-01-2016, 23:55
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: WCP vs Vex Ball Shifter
Both the WCP DS and the VEXpro ball shifters are good quality.
Originally Posted by TabiA View Post
Both with the third stage.
Only the VEXpro ball shifter has a 3rd stage
We've heard about some issues with the vex aluminum shaft wearing down
The output shaft of both gearboxes is made from 7075 Aluminium that is anodised. There shouldn't be any problem with the shaft wearing down when used correctly such as in a WCD. The shifting component either Dog or Ball can wear though.
We would like if we could easily attach an encoder to whichever we choose.
The VEXpro ball shifters allow encoder attachment while the WCP DS does not. If you are planning to use a WCD this is not a problem as the encoder such as a grayhill or a CTRE mag encoder can be mounted to an outer axle. If necessary a CUI encoder, First choice 2015 and 2016 can be mounted to one of the CIM motor shafts of the WCP DS using this great thing http://www.chiefdelphi.com/forums/sh...WCP+DS+encoder
While the WCP DS is designed especially for use in a WCD. The main difference is the type of shifting, the WCP DS is a dog-shifter while the VEXpro ones use a shifting ball. There have been a lot of discussions on this topic on CD previously.
http://www.chiefdelphi.com/forums/sh...t=Ball+shifter
