Go to Post We don't do battle bots, but we play hard. - Gdeaver [more]
Unread 02-01-2016, 16:16
Beaker's Avatar
Beaker Beaker is offline
624 Programming Alum
AKA: Justin K.
no team (No Team)
Beaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to behold
Team 624 Code Release
As Head Programmer of Team 624: CRyptonite, I am proud to present our code from the 2015 season, and the code we developed during beta testing this fall.
Our Robot Code can be found here: http://team624.org/files/624%202015%...%20Release.zip
Besides robot code, this includes a library for using CAN Talons in LabVIEW with limited memory overhead, a scripted autonomous structure and text editor with a customizable programming language, and our version of Smart Dashboard which uses UDP instead of Network Tables. It also contains our offseason RGB lights code.
Our Beta Code can be found here: http://team624.org/files/624-Feed-Forward-R-D.zip
As the name suggests, we experimented with Feed Forward and Motion Profiling in the fall. With some tuning, I was able to get our 2015 bot and a kitbot to go any distance I wanted without encoders (within an inch or two). I am still working on the integration with Feedback to make it more accurate and the latest code will be available on Github. This project may not be able to be opened until Kickoff because older versions of LabVIEW do not support projects built under Beta.
As usual, all of our public code is available on our website and our GitHub page.
Feel free to ask any questions below. The goal of this code release is to help teams of all experience levels.
Team 624 (Student) 2013-2016
BBQ FIRST Creator
Unread 03-01-2016, 09:54
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Team 624 Code Release
The Labview Project for your 2015 code is for a "Later version of Labview". Was this expected?
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 03-01-2016, 09:57
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Yes, I think it was expected
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 03-01-2016, 09:58
jojoguy10's Avatar
AKA: Joe Kelly
I saw that :-) But, it was under the Beta Code paragraph, so I wasn't sure :-)
Unread 03-01-2016, 10:13
Ari423's Avatar
FRC #5987 (Galaxia)
Beta code uses a new version of LabVIEW, which non-beta teams won't get until kickoff. Any code that is labeled as beta won't be open-able until then.
2013: Programmer
Unread 03-01-2016, 10:15
jojoguy10's Avatar
AKA: Joe Kelly
I get that, but I wanted to look at their 2015 Season code, not their beta code. I wasn't specified if their 2015 code was beta or not.
Unread 03-01-2016, 17:25
Beaker's Avatar
AKA: Justin K.
no team (No Team)
Our 2015 Code should not be beta, but it may have been "touched" by the Beta version of LabVIEW. I will update it using one of our computers that doesn't have Beta LabVIEW and has the most recent revision
BBQ FIRST Creator
Unread 03-01-2016, 17:51
Beaker's Avatar
AKA: Justin K.
no team (No Team)
Alright, the correct version should be uploaded. I tested opening it in LabVIEW 2014 and it worked.
Thanks for the feedback!
BBQ FIRST Creator
