WCP vs Vex Ball Shifter
My team is looking at getting a new kind of shifter this year. The two we're currently looking at are the WCP DS three cim gearbox and the Vex Ball Shifter, both with the third stage. We've heard about some issues with the vex aluminum shaft wearing down and haven't found anything on anyone else using the WCP before. We would like if we could easily attach an encoder to whichever we choose. If you've had experience with these and can share your experience it would be very helpful.
Re: WCP vs Vex Ball Shifter
Both the WCP DS and the VEXpro ball shifters are good quality.
Only the VEXpro ball shifter has a 3rd stage Quote:
While the WCP DS is designed especially for use in a WCD. The main difference is the type of shifting, the WCP DS is a dog-shifter while the VEXpro ones use a shifting ball. There have been a lot of discussions on this topic on CD previously. http://www.chiefdelphi.com/forums/sh...t=Ball+shifter Last edited by pilleya : 03-01-2016 at 00:11. |
I haven't heard of the Vex shaft wearing down except briefly in 2014. They have improved it since then so that it no longer wears.
As stated above the encoder attachment is nice. If you have a lathe sticking an encoder on the WCP one is quite easy either by modifying the gearbox upper shaft or on the drive axles. I would just go with whatever is cheap (assuming you can get over the encoder stuff). |
That said for gearboxs I would go with WCP DS, why well I have heard of teams wearing the ball shifter out over a season. After a season with DOG shifted we are planning to reuse internals because the are still in good condition. |
The AMT103-V is almost identical in size to the AMT102-V, the problem is that the encoder output pins are perpendicular to the encoder face, rather than parallel in the AMT102-V. I'm sure it'll be able to work if necessary, but the CIMcoder housing may have to be thicker to account for this, which would result in more output shaft being used up. Last edited by pilleya : 03-01-2016 at 03:42. |
DOG shifting has a much better track record than ball shifting in my experience with FRC. Between the WCP and the VEX I'd use the WCP for this reason. (I know that an all steel andymark supershifter can last half a decade or more. Depending on your resources this may be a worthwile 3rd option, heavy and expensive though.)
The ball shifter is quite a lot more versatile in that it can be more easily used outside of a WCD style drivetrain. The WCP gearbox integrates into a WCD much more nicely (no 3rd stage necessary unless you want to run massive wheels). My experience with the ballshifter using the 3rd stage and versablocks is not very good. There's a lot of load on 4 #8 screws which tend to loosten and are a pain to tighten. YMMV. reiterating the encoder comments We can give you the pros and cons of each gearbox and our opinions on them but it's up to you to weigh these factors and ultimately decide. |
#8
[Citation Needed]
#10
My experience is with super shifters and ball shifters. 1310 got super shifters in I believe 2011 (maybe earlier) and have used the same internals in every year except last. On 865 we used ball shifters in 2014 and by the end of the season they were definitely showing signs of thorough wear. These characteristics have been parroted by nearly everyone I've talked to.
#11
Not trying to invalidate you experience, but just providing a counterpoint to help avoid an echo chamber. |
#12
You bring up a good point about switching tubes (those rookies...) but I would think that would get cleared up relatively fast. Also if one ran their auton in high gear that would mitigate any damage. |
#14
Dog style engagement has a much larger contact area with much more positive geometry. I have yet to encounter someone having serious durability issues with them since the supershifter dogs were beefed up. The ball shifter is an excellent product but I wouldn't buy one expecting to reuse it the way I would with a dog shifting gearbox (especially the steel supershifter). YMMV. |
#15
