Go to Post An explanation of the reasoning behind design decisions will almost always result in a more thorough understanding of the solution than analysis alone can obtain. - Travis Covington [more]
Unread 03-01-2016, 18:50
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Best way to cut VersaFrame
Personally my favorite tool for cutting tubing is a horizontal band saw. You never have to be anywhere near the blade while it is running and they include a vice so that the material is securely held in place.
As far as figuring out where to cut I'd start by using one of the versa gussets lined up with a couple of rivets to create a straight line that is squared to the piece in theory. You can then scribe a line to follow. Now you just need to figure out how to place that line in relation to the blade to get the desired length. You could also line the edge of the blade up with the edge of the gusset so that the cut will be flush with it.
I do like the idea of a jig that would be attached to the saw that would allow you to drop the piece of versa frame over a couple of pins to line things up exactly. Of course you'll also need some way to line up that jig with the saw in case you want to use the saw for other things too.
Unread 03-01-2016, 18:58
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Dry fitting a gusset to the stock material and scribing a line would be the best way to mark the cut line. My favorite way to cut aluminum is to clamp it into a miter saw with a carbide blade installed. You can line the material up with the tooth edge perfectly, clamp in place, and then cut. The carbide blade makes the cut quick and easy and only requires the edges to be broken with a file before it is ready for use.
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 05-01-2016, 12:42
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Check out our thread "VersaFrame Tube Cutting Fixture".
It discusses how we cut our VersaFrame tubing.
Way more involved than most but is the only way to fly when you need to cut 50-100 pieces in an afternoon.
http://www.chiefdelphi.com/forums/sh...64#post1516764
