Go to Post Funding and success is no accident. - waialua359 [more]
Unread 03-01-2016, 20:57
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Basic Spark Linearity Testing
We just completed some basic testing on the Spark, both under load and with no output attached.
http://www.fightingpi.org/Resources/...ntroller.shtml
We're very happy with how it's been acting on our robot so far. We'd like to do more... but #Christmas #Newyears #Reallife #Kickoff
In a perfect world we would have tested with talons and new victors as well, but unfortunately this was done at home. Our build space is locked for the holidays =/.
Unread 03-01-2016, 21:39
Re: Basic Spark Linearity Testing
The small issues we saw in testing may very well have been related to the lack of a "Spark" LabVIEW class, and they only appear at extremely low power levels that FRC robots rarely operate at for extended periods.
I noticed you're a beta team again. As of beta update 5, the Spark is included.
Unread 04-01-2016, 09:39
philso philso is offline
FRC #2587
Tom
Thanks for doing the tear-down and taking the measurements.
Near the end of your write-up, you state "The motor controller did not experience any problems or overheat, and we drained 3 batteries that way." Did you happen to note what the heatsink temperature got to or did you do the old "if you can hold your finger on it, it should be Okay" test?
Unread 04-01-2016, 10:58
Tom Line's Avatar
We did not take any formal temperature data, but the sparks never got so hot that we couldn't touch them without getting burned.
Unread 04-01-2016, 11:30
REVving up for a new season
FRC #2848 (All-sparks)
I assume that means you could always touch them without getting burned....
We were going to publish this today anyway....Here is a Temperature plot that we did based on a 40AMP continuous load @12 volts. We measured 2 data points inside the SPARK (right on the mosfets & on the Capacitors) and 2 datapoints outside (ontop of the heatsink & on the bottom of the plastic case). I am working on the full write up, but this should give you a good indication in the meanwhile.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
