Re: Basic Spark Linearity Testing
Tom
Thanks for doing the tear-down and taking the measurements. Near the end of your write-up, you state "The motor controller did not experience any problems or overheat, and we drained 3 batteries that way." Did you happen to note what the heatsink temperature got to or did you do the old "if you can hold your finger on it, it should be Okay" test? |
We did not take any formal temperature data, but the sparks never got so hot that we couldn't touch them without getting burned.
We were going to publish this today anyway....Here is a Temperature plot that we did based on a 40AMP continuous load @12 volts. We measured 2 data points inside the SPARK (right on the mosfets & on the Capacitors) and 2 datapoints outside (ontop of the heatsink & on the bottom of the plastic case). I am working on the full write up, but this should give you a good indication in the meanwhile. ![]() |
