Go to Post Everyone has regrets in robotics- it's how you learn from them that makes all the difference. - Kevin Leonard [more]
Unread 03-01-2016, 19:23
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Presses and techniques for 1/2" HEX broaches
I was looking at getting a hex broach when it dawned on me that not only would it obviously not fit in our 1-1/2 ton arbor press but also would need quite a large one at that.
Edit: With a 18"+ length Why was I thinking 18"! Thanks Ty. 11-7/8" it is. I guess I was looking at 7/8" hex broaches for some reason? Anyway back to the question.
I'm wondering what other teams have and where to source it from or do you even need a press? Also has anyone used a rotary broach and thinks it would be viable for FRC?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 03-01-2016, 19:26
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Presses and techniques for 1/2" HEX broaches
Originally Posted by jman4747 View Post
I was looking at getting a hex broach when it dawned on me that not only would it obviously not fit in our 1-1/2 ton arbor press but also would need quite a large one at that. With a 18"+ length you can't use just anything so I'm wondering what other teams have and where to source it from or do you even need a press? Also has anyone used a rotary broach and thinks it would be viable for FRC?
Where did you find an 18" long hex broach?
Unread 03-01-2016, 19:41
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Worth mentioning that you can also pick it up from AndyMark: http://www.andymark.com/product-p/am-2204.htm
Unread 03-01-2016, 19:42
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
If your team has an adjustable table drill press that'll probably do the trick. You can lower the press to the height you need then lower the chuck. If you need to push for a few extra inches you can even put the broach inside the chuck.
Many teams don't have one but if you have a lathe you can use a powered-down lath to press the broach.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 03-01-2016, 19:49
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We go to Funky Monkeys to use their homemade press, or to the local community college where they have a very large press.
I would highly recommend against using a drill press to do it. Going to aluminum is hard enough with an actual arbor press, and using a drill press will likely damage it.
Unread 03-01-2016, 19:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Using a drill press as an arbor press is a great way to find yourself in need of a new drill press, and an arbor press....
You can use a sufficiently large lathe, buy it's still no replacement for an arbor press. We have a Grizzly 3 ton arbor press and it has been fine. I would not recommend anything smaller than 3 ton. There's been a few things we've broached where I've found myself hanging off the handle to get it through. Also worthy of discussion is the fact that you need a suitably strong table or stand to bokd it to.
Unread 03-01-2016, 19:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Would one of these work?
http://www.harborfreight.com/20-ton-...ess-32879.html
I have one at home (different brand, 25 years old)....doesn't everyone?
Unread 03-01-2016, 20:08
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
We use almost the exact same one. It works, but there is no easy way to make sure the broach is completely centered.
Also, it takes like 10,000 cycles of the hand lever to broach one thing. It gets very annoying, and takes us way too long. Does anyone else have experience with this, and do you have a good technique?
Unread 03-01-2016, 20:21
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
What the heck are you guys broaching?
I have access to a large 6 ton press in our machine shop but we us a small 1 ton press from Harbor Freight and it easily broaches 1/2 hex in all the material we have used for FRC.
A good sharp broach should have little trouble with aluminum or even cast iron in a small press.
Unread 03-01-2016, 20:22
It looks like you could just swap out the bottle jack for an air over hydraulic one. It won't be blazing fast, but a lot less annoying than pumping the handle a bazillion times.
Unread 03-01-2016, 20:25
REVving up for a new season
FRC #2848 (All-sparks)
Many of the ram ends on those presses are threaded under the cap, if so you can fabricate a custom broach holder, which will maintain the broach being straight. Think of it as a block that is drilled out to the 1/2 round blind hole so that the broach will be supported, then attach it to your press.
As for the 10,000 cycles to broach, you could always convert your press to pneumatic using one of these (or similar) http://www.harborfreight.com/10000-p...ump-98318.html
Assuming you have air power in your shop it might save you some handle pumps.
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 03-01-2016, 22:02
AKA: CAAAAAD
I actually brought home a 3.5" dia 14" stroke pneumatic piston form my summer job, with the intention of converting our press for broaching, but nobody took me seriously, so nothing got done. And now nothing will before build season.. :/
And we actually made a little piece to go on the end of the hydraulic ram, but it is not long enough to hold the broach straight, just in the center of the ram.
Unread 03-01-2016, 23:48
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I calculated that that cylinder only puts out about 1000lbs of force on 100psi. Were you planning on adding a lever arm or something, or is that enough to force a broach though?
I feel like I'm missing something. What's wring with just using the 1/2" shank on the bottom of the broach to keep it straight? Is that not good enough?
Unread 03-01-2016, 23:57
Keeping broaches straight is something that is hard for students (and some mentors) to do without a fixture or jig. Over many year I have seen students kill tons of sprockets, gears & hubs due to a crooked broach). The thickness of the part you are broaching and the material plays a big part in this (the thicker the better).
Unread 04-01-2016, 00:02
AKA: CAAAAAD
I honestly have no idea. I wish I knew, because then I might pursue it further.
We broached some HTD 5mm pulleys that were 1/2" wide, and a few of them came out crooked. This was probably due in part to poor technique (and execution), but I would not trust most of our team members using our current setup for high-speed applications. (where the broached piece is running at high speeds)
