pic: 4587 Wheel and Chain in Tube Drive
Re: pic: 4587 Wheel and Chain in Tube Drive
Live axles or dead axles and why?
Considering there are bearings in the tube where the wheel axles go I would assume live.
Considering that he's using 4x.875 colsons, he's probably using the hex bore ones from Vexpro, so it's probably live axle.
How is the gearbox + wheel going to be assembled onto the robot? It looks like a pain to me, because the colson would cover up the lower 2 gearbox mounting holes. |
live axles, with all of the cots parts available now days, it makes the most sense and it's easier to assemble in my honest opinion requiring less parts and bolts assuming you replace the parts I've used with similar vex parts.
Also the cool thing with a 3 stage ball shifter gearbox is that the third stage actually isn't "part" of the gearbox the way it's assembled makes it fairly easy to mount the gearbox. Additionally given the good track record vex parts have had I don't expect much maintenance ever to be needed, only in worst case scenarios which can't be avoided. |
#7
I'm not sure hiding the chain is as big of a deal as you are making it out to be. Several teams have run chain in tube for several years now with good results. We did it this past year (of course no defense so not a lot of stress) and had no problems. In the 4 years that we've run #25 chain on our drive train we have never broken a chain nor had significant chain stretch. |
