#16
Re: Presses and techniques for 1/2" HEX broaches
In general, if you know that whatever you're inserting the shank into is perfectly perpendicular to the table, that is a suitable means of aligning the broach. To the earlier question in the thread, rotary broaching is viable, but it is also finnicky to get a good fit. We have been using a rotary broach for 5 or 6 years now, but almost every rotary broached part we make, we run a push broach through afterwards to eliminate the "twist" you get in the hex profile due to the way rotary broaching works. The nice thing is no alignment is necessary for this, as the existing hex guides the broach. I would HIGHLY recommend against using anything with bearings to broach (a lathe, drill press, mill, etc). You can brinnell your spindle bearings and destroy them. Last edited by Cory : 04-01-2016 at 01:11. |
#17
I have an old two column press that came out of maintenance shop from the Masonic Temple in Detroit, probably circa 1920's. Works like a charm!
http://www.practicalmachinist.com/vb/attachments/f38/112939d1406518134-large-arbor-press-arbor-press-10.jpg |
#18
Back in the day 1678 would use the knee and turret of our bridgeport to broach 1/2" hex by putting a piece of 80/20 with a central hole underneath and raising the table.
Buy yourself a properly sized arbor press(or modify the arbor on one to have a deep hole and do it in 2 stages). Thank me later. |
#19
Also,
Make sure you hole is true; I prefer a drill and ream to size. You must also lubricate the broach for best results. In my home shop (where the press is) I have used diesel fuel, Kerosene, WD-40, or fine spindle oil. If you slightly back off the ram before each stroke, the broach can recenter itself and stay true to the hole. If you are broaching items thinner than the distance between the teeth on the broach, use a scrap piece with the same hole size to make up the distance and keep the broach running true. DO NOT WIRE BRUSH A BROACH AS YOU WILL DULL IT. DO NOT RUN IT IN BACKWARDS EITHER! |
#20
We just purchased a 3 ton ratcheting arbor press off eBay for $168 (plus $98 shipping) that has sufficient stroke for our hex broach. The press isn't a Dake but should suffice for what we need to do and about 1/10th the price.
#21
On 100 I used to center whatever I wanted broached on the lathe, and run the broach through it using the tailstock. You were pretty much guaranteed that the broach would be centered and perpendicular to the hole, and the tailstock we had could generally handle the forces involved. I realize that it wasn't the greatest for the lathe (especially the ballscrew on the tailstock), but we rarely broached anything thicker/more intense than 1/2" aluminium, and didn't seem to have any issues with the lathe.
#22
#24
Go slow and make sure it feels right! Don't break your broach! I have had a few parts where the broach started walking laterally like crazy and backed off soon enough to save the part and the broach (was not enough lube and it was dragging weird). The broach follows your pilot bore hole, so make sure you have a properly sized (just over .500), straight bore hole for the broach to follow. I recommended experienced mentors do this the first few times because of the cost of the broach, then train students to do it with supervision. We pressed solid aluminum blocks into Vex tubing, drilled and broached them (tubes clamped together to allow a common hex axle). We also broached a ton of .750 OD .125 wall aluminum tube into spacers. Finally we broached about ten different steel worm gears for our tote lift gearbox. Yes, this method is labor intensive, but allows use of a cheap press. For the press and broach you are looking at about $400. We got our broach from McMaster, but AndyMark has them too. If I have time I will shoot a short video. PM me for more details. -matto- Last edited by aldaeron : 04-01-2016 at 13:26. |
#25
Not sure we would buy one yet, we're on the cusp of "it's annoying but a better tool is expensive and this one works" |
#27
