#16
Re: 6 CIM robo-rio brown out
We have gotten better performance on the individual snap actions than advertised. We didn't do a proper analysis, but it seems we've gone about 30-50% beyond those specs (in time) without tripping. We have never really tested the main breaker numbers, because it has never been worth any significant chance of losing EVERYTHING for the rest of the match. As far as I am aware, we've only tripped a main breaker one time in 4-1/2 years. In that one case, we found a possibility of a dead short due to missing insulation, so we fixed that, moved on, and never had it again.
#17
Are you sure of this?
#18
Yes, if viewed from the standpoint of accomplishing a given task, which is how we usually consider the robot design. That is, with loose connections or long runs, you will need to draw more Amp-seconds from the battery to (for example) lift a stack of four totes by fourteen inches.
#19
Someone asked for real world testing with a 6 cim drive. I have some things to report.
The robot tested uses the cRio based control system, but we logged voltage to look from situations where we saw voltage drop below 7.5V. We consider this to be an adequate safety factor to ensure we would be in the clear. Testing completed on slightly lower pile carpet than normal field carpet, but similar in construction. The drive train is configured as follows: Mechanical 2 VexPro 3 Cim Ball Shifters at 18.75:1 and 7.08:1 ratios. 6 VexPro traction wheels 6" diameter 2" width with blue nitrile rough top tread 1/8" center drop Center wheel direct driven. #35 roller chain to drive front and rear wheel on each side Outer axles are bolt-through-tube style dead shafts with bearings in the wheel/sprocket No tensioners used, but chain run has worn in and is not putting un-due load on bearings/gear boxes. Plate and standoff style construction bolted to a box channel core frame ****Robot weight: Roughly 100 lbs**** Electrical 6 Standard Cim motors, all new at the beginning of 2014 competition season 10 awg wire between PD Board -- motor controller -- motors Power pole connector between PD Board and each speed controller as well as between each speed controller and motor 6 Black Jaguar speed controllers on CanBus through a 2Can driving motors Battery was changed 2 times during testing. Programming Smoothing on inputs was implemented in code for this drive train, but still responds sharply and operates precisely Automated shifting used in competition. I need to verify the operational mode used, but I believe 1 speed controller on each side was implemented in speed control mode and the other 2 controllers were slaved to that controller based on current In testing condition shifters were set manually to high or low gear and shifting code was disabled. Results High gear, No compressor, from standing, maximum achievable acceleration -- Would have browned out; voltage dropped significantly below 7.5V Low gear, No compressor, from standing, maximum achievable acceleration -- Would not have browned out; voltage did not drop below 7.5V High gear, Compressor running, from standing, maximum achievable acceleration -- Would have browned out; As expected based on first indicated result Low gear, Compressor running, from standing, maximum achievable acceleration --Not conclusive; Voltage drop below 7.5V, but not below stated brown out condition voltages High gear, no compressor, from standing against wall, ramp to traction limit --Would have browned out; Motor stall achieved critical voltage drop Low gear, no compressor, from standing against wall, ramp to traction limit --Would not have browned out; traction broke before 7.5V limit was reached ****driver modulation to stall condition could force brown out. As much as it pains me to say it, I don't have actual data to share. This was a quick and dirty test and I thought our experience might be useful. I'm convinced automated shifting is of critical importance with the consideration of brown out. I recall a number of teams losing 120amp breakers with 6 cim shifting drives at competition in 2014, which is where this drive base originated, and we never had that problem. Please let me know if you have questions. I'm going to try and set this up and collect actual data early in build season if it appears it might be useful. |
#20
We would start with a fresh battery, get in a few minutes of driving and stacking, then at some point try to turn the robot while carrying a stack and experience the CLACK-CLACK-CLACK-CLACK stutter which told us it was time to change the battery. With a fresh battery for each match in competition we didn't notice it as much. We also did a MacGyver fix by applying duct tape to the treads of the two front wheels to reduce the scrub friction against the carpet. |
#21
Brown-out and under-voltage phenomena occur when the instantaneous current draw is high enough to cause the battery output voltage to drop sufficiently low. The state of charge of the battery will determine the amount of margin that one has before brown-out and under-voltage phenomena occur. A high enough draw will cause a fully/freshly charged battery to drop low enough to cause a problem. A lower instantaneous current will cause a depleted battery to drop to the same voltage level. The recommendations made by Joe are correct. I was questioning the reasoning given for the recommendations. Loose connections will introduce extra series resistance leading to brown-out and under-voltage phenomena occurring at lower instantaneous current than if the connection is good. If the connection is really loose, one will get intermittent operation where the voltage drops to zero. Reducing wire length will reduce the circuit loop resistance leading to higher maximum currents. |
#22
The maximum currents aren't the killer as much as the minimum voltage. If you draw extra amp-seconds to do your tasks, you will have a more drained battery that will be more likely to drop below brownout threshold when you make that big effort at the end (such as a climb, which has a favorite FIRST endgame, including this year's FTC). It is quite unlikely that inefficiency will contribute to the solution more than to the problem.
#23
It is not clear what inefficiency you are referring to in your last sentence. |
