Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Unread 25-03-2003, 17:39
cgDynasty00 cgDynasty00 is offline
cgDynasty00 is an unknown quantity at this point
3ds max problems..
I'm having a problem using 3ds max. When I open a .max file that I've been working on for quite some time now, and then I press M (material editor), i always get an Application Error... It's driving me nuts because i can't get to the mats. ANyone have a clue what's going on? I've been working on patching an F22 Raptor, and this started happening today. I don't know what to do...
Unread 25-03-2003, 17:46
Hailfire Hailfire is offline
AKA: Jason
Hailfire has a little shameless behaviour in the past
Send a message via AIM to Hailfire
Did you install any plug-ins? What does the error say?
Unread 25-03-2003, 17:51
it says, "An error has occured and the application will now close. No scene Changes have occured since your last save."
All my plug-ins work fine.
however, last night, i installed a new mouse, and that's when i started to act up... but jsut now i changed back to my old mouse, and same thing.... i dk what's wrong.
Unread 25-03-2003, 17:55
AKA: Jason
Hmmm, something like this happened with me too. Except, there were no problems with anything in max (Except trying to open previously saved files). Well, one thing you can try to do is, restart your computer. If that doesn't work, try testing 3dsmax by making something really fast, save it, and try to reopen it. If it opens up, then everything should be fine. Another thing you could try is saving it as a .3ds file and importing it or just make two files of the same thing in case something like this does happen. Anything other than the things I've listed here, I don't know what to do. Hope this helped.
P.S. Try to uninstall the mouse software too and retry it.
Unread 25-03-2003, 18:18
AKA: Jason
Here's one thing to keep in mind, take everything into consideration. If those options mentioned above don't work, try contacting customer support.
Unread 25-03-2003, 18:20
true.
Unread 25-03-2003, 18:52
hmm... i quickly made a cube and applied the default texture to it, and save it as cube.max , then i re-opened it, and i press M , and i got that same error message....
Unread 25-03-2003, 18:55
AKA: Jason
Did you try restarting your computer? Restarting your computer would free up all of your RAM because 3dsmax tends to use up lots of it. So if you don't have a large RAM chip (anything greater than or equal to 128MB), this could cause a problem and it'll refuse to open. Another possibility may be that you have too many programs opened. Close all of them and just leave 3dsmax open.
Unread 25-03-2003, 21:39
my comp is pretty decent for max. I've tried restarting a couple times, but that didn't help. I also tried ending some unnecessary Processes. It's now a problem for all my max files. I want to model so badly...
I'll try beefing up my comp, right now my PC specs are:
p4
40gb (which has gone down to 15.8gb)
gf4 ti4200
512mb
1.8 ghz
Unread 26-03-2003, 07:36
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
2 ideas to help you
First, there are autoback files that are made every 5 minutes or so by your computer. Go find them and see if your file was in there (in your 3ds max directory in autobak folder). Look at the date and time and maybe the thumbnail pic, and then see if your file is there. You may have to change the extension from .bak to .max (can't remember) I personally autobak about eevry 5 minutes, just in case.
If that doesn't work, there's only 1 more thing you can do. Uninstall it, throw up a prayer, and re-install it. If the problem persists, then contact autodesk, cause there's nothing more you can do.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
All Programs Hate 3ds max LBK Rules 3D Animation and Competition 1 12-03-2003 22:31
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
