Go to Post we need a diverse team, and until we can welcome someone that's not a nerd, I don't think we're really successful in our recruiting. - JBotAlan [more]
Unread 04-01-2016, 18:45
rishabkatti rishabkatti is offline
FTC #8468
rishabkatti is an unknown quantity at this point
[FTC]: Climbers in Autonomous
Hi, I was wondering if we get the climbers in autonomous will we get the points again in tele-op?
Unread 04-01-2016, 21:27
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: [FTC]: Climbers in Autonomous
The two robot loaded climbers, if scored in the beacon bin during autonomous, will be totaled for 20 points at BOTH the end of autonomous period, and another 20 points at the end of match, for a total of 40 points of scoring.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 05-01-2016, 09:59
DadInaDaze DadInaDaze is offline
FTC #2887
Team Role: Parent
DadInaDaze is an unknown quantity at this point
Seconding what Mr. RRL said, and adding...
... for our team's first tournament, we decided, last-minute, to not try dropping climbers in Autonomous. Our "dumping" wasn't as reliable as we hoped, so we figured we had more likelihood of successfully scoring in driver-control / tele-op mode.
Unless you have a good mechanism to scoop-and-drop climbers that are the floor, you don't want to blow your one chance to score climbers. To quote another mentor: "Zero times double-points is still zero."
Other factors to consider are 1) whether alliance partner robots will also try the same achievement-- keep in mind there's only a half-minute total for both robots to position and drop successfully and 2) whether the robot and program can endure debris, alliance partners, or opponents veering you off-course
I saw that last example happen once... both robots delayed Autonomous movement to avoid penalty, and opposing robot legally crossed into opposite alliance's zone and bumped a robot off-course; timing was perfect. The affected robot tipped its climbers harmlessly onto the field. An event not likely to happen, but nonetheless a possibility, and a strategy some teams could use to advantage.
