Go to Post Brandon, it's not an issue... but the fortune cookie thing that you get when you give someone rep is a little creepy... - Beth Sweet [more]
Unread 05-01-2016, 11:01
Chris is me's Avatar
AKA: Pinecone
Re: 2x1x1/16 Belt-In-Tube
Originally Posted by JesseK View Post
Just came to a realization here - do the top & bottom of the side frame rails for a belt-in-tube design become (effectively) unusable? Putting even a rivet through the wall would interfere with the belt or chain, correct? How do teams account for this?
Teams either use bigger tubes for more clearance (with belt in tube designs - chain-in-tube takes advantage of the close fit), or they put two hole patterns down the length of the tube and just rivet to the opposite side of the chain.
