Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 05-01-2016, 12:01
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
VersaFrame Tube Cutting Fixture
https://drive.google.com/file/d/0B67...ew?usp=sharing
For the last few years Team 2451, Pwnage, has been using 1"x1"x.04" VersaFrame Tubing to build our chassis. Last year one of our alumni (current mentor) converted an existing fixture to speed the cutting process and increase the precision of cutting the VersaFrame tubing to size. During the offseason he has designed and manufactured a brand new cutting fixture. This fixture is installed in a Curt Vise in a Bridgeport mill. A horizontal head attachment is used to drive the slitting saw blade in a vertical orientation. The finer the toothed blade the less likely the thin wall tubing will be bent during cutting. The angle of the cut is adjustable and graduated marks are provided for quick adjustment. The tube is positioned in the correct location using a precision pin inserted through the existing VersaFrame mounting holes which engages a precision reamed hole in the fixture. This allows for a single value to be changed in the Prototrak 2D CNC controller, the angle to be adjusted (if needed) and the blade to cut the tube to the correct length.
Unread 05-01-2016, 12:09
AdamHeard's Avatar
Lead Mentor
Re: VersaFrame Tube Cutting Fixture
Why do you need to cut so precisely (and tie up a nice machine) if you're attaching with gussets/sheet anyway?
Unread 05-01-2016, 12:39
FRC #2451 (Pwnage)
The main reason for the fixture is to save time.
Though, when you cut and join the tubes precisely, allow them to butt up against one another, the load in not 100% on the rivet and gusset. The load can be distributed directly from one tube to the other. This makes the fastening stronger and the complete assembly more rigid. Especially if you are using .04" wall tubing which has a lot of deflection under load when only using rivets.
We have six Bridgeport/Prototrak mills.
There are times where we "tie up" all six but there is usually at least one open. The actual cutting takes the same amount of time as any other method. The setup time is minimal when you look at the overall time savings. We used to hand measure, mark lines with a square or a protractor and then manually cut the tubing. When you have 50 pieces to cut the fixture is a big time saver. Plus the tubes fit together the first time.
Unread 05-01-2016, 13:11
philso philso is offline
FRC #2587
This is a great idea that should save you a lot of assembly time. Can this jig be used for cutting other materials such as shafts? I will see if we can come up with something similar for the basic equipment we have (bandsaw, hacksaws).
I now have a strong case of shop-envy.
Unread 06-01-2016, 10:05
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Seriously. Six mills? I don't think we even have six shop tools in total!
Oh well, we'll get there...
