Go to Post You won't find this in a manual anywhere but you will need COUGH DROPS!! If you haven't started losing your voice by Friday afternoon, you aren't getting the full experience. - wendymom [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 04-01-2016, 06:27
Cinnamon Toast's Avatar
Cinnamon Toast Cinnamon Toast is offline
FRC #3641 (The Flying Toasters)
Cinnamon Toast is an unknown quantity at this point
Best CAN Connector Interface
FRC Community,
This coming year our team plans to use mostly Talon SRX controllers as our main motor controller on the robot. We've got the stock and we are excited to use them! In the past the mess of PWM wires going back to the roboRIO or CRIO has been atrocious. We hope that by leveraging the use of the CAN bus for the motor controllers, we can have less of a rats nest of wiring. This being said, the lack of modularity is a bit concerning. In the past, if we were to spit a motor controller somehow, we would simply disconnect the power connector and the PWM cable and switch it out. With the twisted pair and daisy chain style of wiring with the CAN interface on the Talon SRX's, this isn't as easy assuming that we solder the CAN wires together. I'd like to put some type of connector between the CAN connections, but what should I be using? I know that there needs to be so many twists per unit distance so should I not use a connector between the daisy chained controllers at all? I just have concerns about being able to switch the controllers out. I'd prefer not to have to snip wires all the time. I'm open to all suggestions!
-Cinnamon Toast
Unread 04-01-2016, 12:34
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Best CAN Connector Interface
Hey Cinnamon Toast,
We sell a CAN connector that uses the same wire-insert strategy as PCM and PDP for coupling two Talon SRXs together.
http://www.ctr-electronics.com/can-c...or-5-pack.html
This way teams can chain them up without soldering and therefore can make changes to the robot quickly.
Other teams have also come up with different solutions last season that I think are worth checking out...
http://www.chiefdelphi.com/forums/sh...r+we idmuller
Also checkout sections 1.3.2 and 1.3.2.1 in the Talon SRX User's guide...
http://www.ctr-electronics.com/talon...ical_resources
...for some good tips about wiring. CAN Connectors are mentioned there.
You don't need a very precise means of twising the wire. Most teams just acquire 20 or 22 gauge green/yellow wire, and use a drill to quickly twist them. You can also purchase them pre-twisted...
http://www.ctr-electronics.com/cabli...able-10ft.html
I use a mix of CAN Connectors and Anderson Power poles and have been successful with both.
Make sense to me I think you'll be happy with the result.
Unread 04-01-2016, 19:03
One of the most interesting suggestions I've seen for Talon SRX CAN connectors is to use the outer two pins of a female PWM connector. The SRX also accepts PWM input, and that makes it compatible with the PWM pins on the RoboRIO. To connect two of them, use a 3-pin straight header to join them (with or without the center pin). Electrical tape to hold them together would probably be a good idea.
Unread 04-01-2016, 22:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
So far, we haven't used enough PWM controllers to need any connectors other than the weidmullers built into the RIO, PDP, and PCM. We purchased several of the connectors Omar referenced above. We have only used them so far on test boards (no inter-robot contact), but have had no issues.
In recent years, we have intentionally wired up one or two "hot spare" motor controllers (recently Talon SRs) so that by moving an Anderson pair and changing one character in our RobotMap we could be up and running again. With CAN Talons, you may have to also move the limit and encoder/analog sensors to another controller, but that's still better than rewiring the CAN bus if time is short.
I would only directly solder or crimp the CAN bus of two controllers if I had a big enough budget to keep each robot for many years, and never cannibalize it for parts. If I were to use a crimp or solder connector, I would want a polarized genderless connector (Molex has one out this year for this gauge). Note: Last year, motor controllers with connectors crimped on were considered COTS for build season, but not for the withholding allowance. (compare R12 and R17, particularly as to the a, b, and c bullets - only R12 has a c bullet).
Unread 04-01-2016, 22:45
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Last year we used a multi terminal strip to do the cans.
https://www.radioshack.com/products/...ant=5717454469
Unread 05-01-2016, 08:02
Toast,
There are a number of connectors that work in this application. All of them available from Digikey (First sponsor in Minnesota). If you have good soldering skills and can handle the cost, Switchcraft makes a mini version of their XLR connector line. These connectors latch together so they won't pull apart in high G collisions and are available in 4 pin version. My personal recommendation is to select a connector solution that can easily be pulled apart and then allow the offending device to be isolated by connecting to the remainder of the string.
Unread 05-01-2016, 08:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
These connectors .. are available in 4 pin version.
Why would you want 4-pin connectors for this application? Do you use chassis harnesses, doubling the number of connections over a daisy chain? If not, you would have to attach half of the devices to each other by hard connections on one side of the connectors, which doesn't help much when it comes time to repair.
Unread 05-01-2016, 08:15
Gus,
If your robot design would have the connectors removed from the devices by some distance, four pins would allow the bus to go to and return from the device.
Unread 05-01-2016, 16:14
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Obviously you just put the thing in the thing Ethan. And if that doesn't work, add duct tape!
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 05-01-2016, 17:01
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
^^^^This (mostly)^^^^
We crimp our own PWM cables so we can make them custom length, so using the same connector just made sense to us. Rather than use a straight header in between two female PWM connectors though, just make one of them male. Then they can just plug into a chain, making sure you match up the colors. You can also stick a zip tie in the middle to hold the connection secure.
Unread 06-01-2016, 07:29
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Personally, I would have liked the Talon SRX to have included the above connectors built right in to the device for the CAN interface.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 06-01-2016, 14:44
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell will become famous soon enoughdroswell will become famous soon enough
We used Anderson 15A power poles to have a quick disconnect for our CAN bus. A bit overkill? Sure. But they worked great and with the right crimping tool were a breeze to install. We also use the 45A on the mains. By changing the orientation of the connectors we could make it impossible to plug the wrong thing in the wrong place. We get them here:
http://www.powerwerx.com/anderson-po...ings-contacts/
Unread 06-01-2016, 16:53
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
This was considered during development of the Talon SRX. However the overall footprint and weight of the device would have increased. It was decided that, due the increase in real estate, and the fact that teams have their own preferred methods of connectorization, it made sense to use the existing strategy.
Mike Copioli
CTRE Hardware Engineer
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 21-02-2016, 15:25
DavidOrser DavidOrser is offline
FRC #2987
DavidOrser is an unknown quantity at this point
This thread has quite a few good ideas, but I thought I'd share our solution as well. We originally tried DC barrel-plug power connectors and 3.5mm headphone jacks, but the available connectors from Digikey were too expensive and the cheap ones we got from Amazon were of very poor build quality (didn't fit well, solder terminals kept shorting). In addition these solutions still required electrical tape to keep them secure and short free.
We finally settled on these small gauge Wago "Lever Nuts":
http://www.amazon.com/gp/product/B00HIOP6SC
They are *extremely* robust and require no soldering or shrink tubing and are tool-less to change out or reconfigure. They have zero exposed wire to risk shorting. When stress testing them we broke the 28awg stranded CAN wire before the connector teeth gave out. The only downside is they can be a bit rough on the fingers when opening and closing. To wrap it all up, they are *cheap* and fast at $0.30 per connector with free (Prime) 2day shipping.
One of our best finds this season
Good luck out there!
