Go to Post I highly doubt the game has anything to do with water... - rotolomi [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 01-05-2016, 05:01 PM
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Re: Best CAN Connector Interface
Originally Posted by Alan Anderson View Post
One of the most interesting suggestions I've seen for Talon SRX CAN connectors is to use the outer two pins of a female PWM connector. The SRX also accepts PWM input, and that makes it compatible with the PWM pins on the RoboRIO. To connect two of them, use a 3-pin straight header to join them (with or without the center pin). Electrical tape to hold them together would probably be a good idea.
^^^^This (mostly)^^^^
We crimp our own PWM cables so we can make them custom length, so using the same connector just made sense to us. Rather than use a straight header in between two female PWM connectors though, just make one of them male. Then they can just plug into a chain, making sure you match up the colors. You can also stick a zip tie in the middle to hold the connection secure.
