Go to Post See, building a really great robot is just a pseudo challenge for the concept of the whole FIRST program. It is just a phony way to bring people together to reach one common goal. - sanddrag [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 25-03-2003, 23:28
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
Listen-to xml parsing example thingie
well, i got bored one day and tried some xml parsing based on some examples i found on the web for Listen-to. don't know if anyone is interested. Prolly not very efficient but hey. I basically just made it output an image (which you can already do) but you could do anything you want with the data. comments are good
PHP Code:
<?php
$file
"http://www.listen-to.com/xml.php/trashed20";
$depth = array();
$data1=array();
function
startElement($parser$name$attrs) {
global
$name;
    global
$depth;
    for (
$i 0$i $depth[$parser]; $i++) {}
$depth[$parser]++;
function
endElement($parser$name) {
    global
$depth;
$depth[$parser]--;
function
characterData($parser$data) {
global
$data1;
if (
$data!="    "){$data1[] =$data;}}
$xml_parser xml_parser_create();
xml_set_element_handler($xml_parser"startElement""endElement");
xml_set_character_data_handler($xml_parser"characterData");
if (!(
$fp fopen($file"r"))) {
    die(
"could not open XML input");
while (
$data fread($fp4096)) {
    if (!
xml_parse($xml_parser$datafeof($fp))) {
        die(
sprintf("XML error: %s at line %d",
xml_error_string(xml_get_error_code($xml_parser)),
xml_get_current_line_number($xml_parser)));
xml_parser_free($xml_parser);
header ("Content-type: image/jpeg");
$im = @imagecreatefromjpeg ("temp2.jpg");
$tc  imagecolorallocate ($im255255255);
$time=date("m/d/y g:i a",$data1[11]);
$track=$data1[7];
$group=$data1[3];
imagestring ($im32307$timeblack);
imagestring ($im312631$groupblack);
imagestring ($im313652$trackblack);
imagejpeg ($im,"",85);
Where has all the fun gone?
Unread 26-03-2003, 00:14
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
very cool.
Brandon Martus
e-mail
Unread 27-03-2003, 00:44
gliebowitz gliebowitz is offline
#0075 (RoboRaiders)
gliebowitz is an unknown quantity at this point
Send a message via AIM to gliebowitz
I'm doing some client work now using "web services" (buzzword) and SOAP to integrate an inventory database with various platforms.
On my team's homepage, XML was used to dynamically feed info to the news system from a simple Access db (Flash and static pages) with ASP... not PHP. http://www.roboraiders.com
How long have you been working with PHP?
Greg Liebowitz
Programmer/Webmaster
Team 75 - RoboRaiders
www.itmediaco.com
Unread 27-03-2003, 07:07
Trashed20's Avatar
i've been working with php since may of last year. I wrote our whole website ( http://www.lightningrobotics.com ) in php and using mysql. Making xml files to parse for every time someone wants to access your news is prolly pretty hard on your system. Doesn't ASP have dirrect connections to access db's?
I chose php as it is c++ structured and syled which i like
Unread 27-03-2003, 15:13
#0075 (RoboRaiders)
Cool
A connection is made to an Access db just like you would do for any other ODBC connection. The server we're using is a 1.4 Ghz P3 Dell, so it doesn't seem to get bogged down too often ;-).
If you are interested, this is the code to the asp script requested by the Flash intro to get the latest news:
PHP Code:
var months = new Array ("jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec");
var
monthValue = new Array (13,14,15,16,17,18,19,20,21,22,23,24);
var
now = new Date();
var
month now.getMonth();
var
date now.getDate();
var
day now.getDay();
var
year now.getYear();
var
week 1;
if (
year 2000year year 1900;
var
monarr = new Array(31,28,31,30,31,30,31,31,30,31,30,31);
if (((
year == 0) && (year 100 != 0)) || (year 400 == 0)) monarr[1] = 29;
sday day;
while (
date != 0){
date --;
sday --;
    if (
sday 0){
sday sday 7;
week ++;
var
currentMonth months[month]
var
currentWeek week
var current_category monthValue[month]
var
out
sql
"SELECT * FROM data where data_category = " current_category " order by data_subcategory, data_name";
rs Server.CreateObject("ADODB.RecordSet");
rs.Open (sqlConn2,3);
if (
rs.EOF){     // check to see if rs is empty
out += ('    <button name="No articles">\n')
out += ('        <info>There are no new events for this week.</info>\n')
out += ('    </button>\n')
else{
// rs not empty
temp_subcat""//this string used to group records by subcategory
fields = new Object(); // this object used to store fields in records
while (! (rs.EOF)){
// clean up data and put it into the fields object:
for ( field_number 0field_number rs.fields.count field_number++ )
temp_field String(rs.fields(field_number).Name);
temp_content String(rs.fields.item(temp_field));
temp_content temp_content.replace(/&#039;/g,"'");
if (temp_field.search(/date/) > )     // check for date fields
{temp_content slash_date(temp_content);}
        else if (
temp_content == "null") {temp_content ""; }
fields[temp_field] = temp_content
// end looping through fields in current record
        // subcategories: when we get to a new one, display it
if (temp_subcat != fields.data_subcategory){
temp_subcat fields.data_subcategory;
if (
temp_subcat == currentWeek){
out += ('   <data>\n')
out += ('    <name>'+fields.data_name+'</name>\n')
out += ('    <info>'+fields.data_url+'</info>\n')
out += ('    <id>'+fields.data_uid+'</id>\n')
out += ('   </data>\n')
        } else {
rs.move(1);
// end while recordset
     // end else (rs not empty)
rs.Close ();
if (
out==""){
out += ('    <name>No articles.</name>\n')
out += ('    <id>undefined</id>\n')
Response.Write(out)
Conn.Close ();
Greg Liebowitz
www.itmediaco.com
XML Parsing Jack FIRST Scouting Network 1 12-10-2003 13:36
XML And Link Raven_Writer Website Design/Showcase 13 26-09-2003 17:24
xml Jack FIRST Scouting Network 0 01-09-2003 16:23
[Tech] - XML Parsing Jack FIRST Scouting Network 3 20-05-2003 16:42
Does FIRST listen to teams? archiver 2001 5 24-06-2002 04:01
