Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
  #43   Spotlight this post!
Unread 06-01-2016, 16:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: [FRC Blog] Surprise!
Originally Posted by Cash4587 View Post
I was more referring to the totes. Also, I think unless they make a rule change I don't think the solid pool noodles are legal to be used in bumpers.
Emphasis mine:
Originally Posted by 2014 R21, part C
use a stacked pair of approximately 2 ½ in. round, petal, or hex “pool noodles” (solid or hollow) as the BUMPER cushion material (see Figure 4-8). Cushion material may extend up to 2 ½ in. beyond the end of the plywood (see Figure 4-5 and Figure 4-9). To assist in applying the fabric covering, fasteners may be used to attach the pool noodles to the wood backing, so long as the cross section of Figure 4-8 is not significantly altered (e.g. tape compressing the pool noodles).
Edit: ... and 2015 didn't say what you could or couldn't make them from, apart from the general robot rules.
