Go to Post After assisting with the animation last year I realized how cool and useful Inventor was and I started flirting with it. Half a year later I think I have lost all possibility of ever having a girlfriend, and frankly I don't care because I would definately bare the child of this program. - negfrequency [more]
Unread 06-01-2016, 18:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: WildStang: Swerving up something new
Originally Posted by Bryce2471 View Post
I just thought I should chime in here to say that team 2471 built a swerve with both the upper and lower mechanisms constructed in aluminum box tubing, and we loved it. Even with zero CNC machining, it was very easy to build, lightweight, and crazy strong.
The prototype module.
That doesn't mean this the right way to build a swerve for everyone, just that it worked well for us. We had freshman and sophomores make the boxes on a manual Bridgeport early in the season when there was nothing else for it to be used on.
The final iteration weighed just under 7 lbs, and we had zero mechanical failures from the system.
There we go. We're at that end of the spectrum - up till now we haven't had a decent brake, and we just got an in-house manual mill last year. So box-stock was always the way I pictured a swerve for us, and it seems that just being able to through-drill holes takes a lot of potential alignment and tolerance issues out of the equation. In fact, a number of times in the past we've actually welded our chassis and drilled the axle holes after the fact for the same reasons - to eliminate the tolerancing issues that we have with poor tools and students who are just learning =).
Unread 07-01-2016, 17:25
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Another reason why we decided to go for a sheet metal wheel cage is because we wanted a versatile part. By making it sheet metal, we were able to have both a 3 inch and a 4 inch configuration, so we had the ability to manufacture both easily.
The prototype we built up has the 4 inch configuration, it was supposed to be the 3 inch, but some drawings got mixed up and the 4 inch configuration was sent to our sponsor instead. This resulted brought up a few problems with the design, but nothing a dremel couldn't fix.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 07-01-2016, 22:42
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
To follow up, our prototype code is now posted up on Github here. This is built on top of our new framework, so you would need the core_framework repository as well to be able to run it.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
