Go to Post Did you NOT see the last caption contest???? - Tom Schindler [more]
Unread 06-01-2016, 17:57
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Standard Question?
What are people using as the standard supports? Wood, PVC, or something else? Can you please post some pics if possible?
Unread 06-01-2016, 18:21
waffle_dynasty waffle_dynasty is offline
FRC #5010
waffle_dynasty is an unknown quantity at this point
Re: Standard Question?
I think Bluejackets' question refers to the Team Standard (flag-like thing). My team made ours out of two 1/2" diameter wooden dowel rods. We attached them to each other by drilling two holes into a wooden block so when the dowel rods were inserted they made a T. We use eye-hooks to attach our flag to our support
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
While our team hasn't started working on our standard yet to my knowledge, really it's up to you. I personally would recommend wood, seeing as it's more aesthetically pleasing for a standard, and you can change the woods darkness or paint it easier to make it look better with the standard's main color scheme.
Note, PVC is probably a bit cheaper, but wood looks a lot better
Unread 06-01-2016, 18:48
Robopromo's Avatar
Robopromo Robopromo is offline
FRC #2474
Robopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of light
Robopromo is offering Team Standard materials this year (kits and raw materials). Our design includes a wooden cross beam that is ready for assembly.
Check out pictures our designs using the link below:
http://www.robopromo.com/product_p/rp-6003.htm
Unread 06-01-2016, 20:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Honestly, my first thought on reading the specification was aluminum tubing. Wood is good, PVC will probably last through build season. If you like to keep displays up for years into the future, make sure you keep PVC out of the sun and other UV sources. The team is supposed to decide on a design tomorrow.
