Go to Post As long as the competition gets the attention of someone and drags them in, it doesn't matter how they get there. - Andy Grady [more]
Unread 07-01-2016, 01:36
Liquid_Science Liquid_Science is offline
FRC #2996
Liquid_Science is an unknown quantity at this point
pic: 2996 Octocanum Prototype
Unread 07-01-2016, 01:37
AdamHeard's Avatar
Lead Mentor
Re: pic: 2996 Octocanum Prototype
I'd be concerned about the slender shafts that front and rear of the cylinders attach to. They might not have enough stiffness.
Unread 07-01-2016, 07:55
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
This looks great! Is the weight an issue? Ive seen some really heavy octocanum drives before.
Unread 07-01-2016, 08:08
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
Originally Posted by Liquid_Science View Post
looks pretty cool, but I'm not exactly sure how that type of drive train is beneficial, could you explain? I've never seen or heard of it before, so I don't know anything about them.
Unread 07-01-2016, 08:32
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
The idea is that you get the best of both worlds: mecanum wheels for maneuverability and traction wheels for pushing. The main downsides are weight and complexity.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 07-01-2016, 08:48
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
What was your reason for putting the traction wheels on the pivot? In my team's design, we placed the mecanums on the pivot because then, when you retract the traction wheels, you don't need as much cylinder force to hold them off the ground. For traction mode, the mecanums barely need to be off the ground or can be slightly touching- the cylinders don't need to support nearly as much weight. In your design, the cylinders need to hold the whole weight of the robot up off the ground so only the mecanums are touching.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 07-01-2016, 08:54
FRC #2996
We managed to get the weight right around 54 pounds with everything needed to run the bot (electronics, pnematics, ect.)
Unread 07-01-2016, 09:04
FRC #2996
The biggest reason is we wanted to use 4in casters and 6in Mecanums. The cylinders we used should be plenty enough to lift even a fully weighted robot, since the boar on each is 1.5" with a 1" stroke, and there are 4 of them. Aslo, we wanted the casters to be the default wheel if something failed. The two wheels can easily be switched around, if we wanted to run 6in casters and 4in mecanums; depends on the game really.
Unread 07-01-2016, 09:06
JoshWilson's Avatar
Ok, that makes a lot of sense. Thanks for the explanation!
Unread 07-01-2016, 09:38
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Have you thought of doing a single larger cylinder between the two modules a la Blue Cheese. Might be less parts and less weight.
What is your gearing for each wheel shaft in the pods from the CIM?
Are you concerned about deflection when the mecanums are down? Seems like a much longer moment arm around the rotation axle. I have wondered this for all the octocanum designs I have seen on CD. It seems like you would want to support the end of the axle that the pod rotates around with a bearing and have an external frame rail running the length. Perhaps the plate between the two pods is enough. Have you tried stacking weight on it to get the bot to 150 pounds?
Love the FIRST logo in the frame =)
-matto-
Unread 07-01-2016, 09:41
Chris is me's Avatar
AKA: Pinecone
Two great reasons to pivot about the traction wheels. First is that traction wheels will see a lot more force in all directions than the mecanums will, especially when being pushed from the side. Pivoting about the traction wheels means these wheels are more rigidly supported by the whole frame. Additionally, mecanum wheels seem to behave better when on a suspension, and the cylinders will serve as a form of a suspension, helping to ensure all of the wheels are touching the ground. The amount of cylinder force for holding one wheel off of the ground instead of the other really shouldn't change in either case.
Unread 07-01-2016, 12:45
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
How does this drive train plan to handle bumpers?
GitHub
Unread 07-01-2016, 12:55
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I really enjoy looking at these types of drive trains. Back in my days these types of drives were never heard of. I made something to try and accomplish what this does.
These are cooler to see people make for sure.
Unread 07-01-2016, 13:11
JesseK's Avatar
FRC #1885 (ILITE)
You should provide a link. That type of drive train hasn't been seen since. It was really cool for its time, IMO.
GitHub
Unread 07-01-2016, 13:21
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Wow, pretty!
I would really recommend extending the outer plates that join your pivot points all the way out to the front and back plates if you can. I'd be worried about cantilevering those huge assemblies off the side of a pair of bearings that are only < 1" apart! Doing so would also let you support your side bumpers for more of their length (the 2014 rules required support every 8").
