Go to Post At the Chesapeake Regional, we will be weighing any team that brings in a kitchen sink (or other major appliances) or an extra robot... - RoboMom [more]
Unread 07-01-2016, 11:57
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Flux Rings
So I was researching the smaller motors yesterday and I started to read about the flux ring that confines the magnetic field. That lead me to the question of how big of an effective does the flux ring have on their performance?
Also a second cosmetics questions. Would it be against the rules to laser etch or paint you team logo on the flux ring of a motor?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 07-01-2016, 12:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Flux Rings
As to performance, I do not know, though I have read observations that it reduces top speed and conjecture that it may improve torque.
As to marking, the applicable rule from 2015 is:
Originally Posted by 2015 Game Manual
R19 The integral mechanical and electrical system of any motor may not be modified. Motors, servos, and electric solenoids used on the ROBOT shall not be modified in any way, except as follows:
  • A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
  • B. The electrical input leads may be trimmed to length as necessary.
  • C. The locking pins on the window motors (P/N: 262100-3030 and 262100-3040) may be removed.
  • D. The connector housings on window, door, windshield wiper or seat motors and Bosch motors (P/N: 6004 RA3 353-01)
  • may be modified to facilitate lead connections.
Painting would certainly not modify the integral electrical and mechanical system (unless it were acid paint, or something else that modified the strength or electrical characteristics of the motor parts). Etching would (if the 2016 rules match this) be a Q&A issue, for which I would expect that it is OK, but the rules committee might decide that even a tiny bit of metal removed modifies the magnetic field, and therefore the electrical system. If you ask the question, I would suggest asking the full question as to whether the flux ring can be removed; not that you necessarily would want to, but if it's not an option, it'll save some testing. If removing the flux ring were allowed, I would probably want to have that motor as far away from the radio and any signal lines as possible.
Unread 07-01-2016, 12:41
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Flux Rings
I had a discussion regarding flux ring removal many years ago with Joe Johnson. He was working for Delphi at the time, and was a lead mentor for Chief Delphi Team 47. Removal of the flux ring will significantly reduce moror performance. Maybe Joe will read this thread and chime in on this question.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 07-01-2016, 13:32
Dennis5045's Avatar
Dennis5045 Dennis5045 is offline
AKA: Dennis Taylor
FRC #5045 (SpartaBot)
Dennis5045 is an unknown quantity at this point
Re: Flux Rings
You should see no problems till you get up to 88 mph. The rings reduce RPM, but increase torque and efficiency.
Unread 07-01-2016, 13:37
Munchskull's Avatar
Team Role: CAD
Re: Flux Rings
So would you say flux ring removal could be an effective way to to speedup a motor without changing the gear reduction? Also it would be cool to see Vex do their motor test with out the flux ring.
Anthony Cardinali
4th year of FRC
Class of 2017
