Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
Unread 07-01-2016, 13:26
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
paper: Apalrd's Choo-Choo Analysis Spreadsheet
Thread created automatically to discuss a document in CD-Media.
Apalrd's Choo-Choo Analysis Spreadsheet by apalrd
Unread 07-01-2016, 13:28
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: paper: Apalrd's Choo-Choo Analysis Spreadsheet
By 'Choo-Choo' do you mean the kick-driving mechanism that 148 did in 2010? I'm not familiar with your 2014 bot's inner workings.
GitHub
Unread 07-01-2016, 13:53
apalrd's Avatar
More Torque!
VRC #3333
148/217's 2010 mechanism is a snail cam, not quite like this.
Winnovation (1625) 2010 used a choo-choo, but it was mostly popularized by the 2014 Build Blitz where Team JVN used it.
Here's a graphic I found on CD a few years ago (but couldn't find it with a google image search). Thankfully I saved it. Here it is:
In my spreadsheet, the blue link is the 'fling' arm and the red link is a cable which connects to the throwing arm. The length of the red link is not important as long as it pulls straight down on the throwing arm. Some designs use a hard link instead of a cable for the red link.
Kettering Motorsports
Unread 07-01-2016, 15:49
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Also used by team JVN in the 2014 BuildBlitz
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 07-01-2016, 15:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FYI - the choo-choo cam was used by Winnovation in 2010 and JVN's 2014 Build Blitz. Those two teams had one thing in common (Aren Hill) and that is no small coincidence. ;o)
Unread 07-01-2016, 16:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I definitely like how the launcher can be held fully cocked with little torque required from the motor; probably little enough to let the gearbox hold it (especially if that last 12:1 reduction is through a worm gear).
Is the driven axle assumed to be located midway between the "pivot" and the "pin" mounted to the disc? Have different axle locations been investigated?
If the axle was not in the line between the pivot and the pin (below this line when horizontal), it appears that the two drive periods would overlap and merge into a single steadier pull, at the cost of introducing a null sector at the opposite part of the cycle.
Unread 07-01-2016, 17:02
Volunteer, WPILib Contributor
no team (Waiting for 2021)
You can also use something like a ratcheting wrench to be an anti backdrive. Unless you want to be able to slowly release, the choo choo only ever needs to rotate in 1 direction.
Team 4488 - Mentor 2013-2016
Unread 07-01-2016, 18:20
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I also believe it was in their 2008 robot also if memory serves me correct.
Unread 07-01-2016, 18:44
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thumbs up Re: paper: Apalrd's Choo-Choo Analysis Spreadsheet
We were in an alliance with Winnovation when they used the choo-choo to win the Colorado Regional in 2008. At the 2014 kickoff we were making train sounds as soon as we saw the game! We ended up using a choo-choo cam and made the hub of the sprocket a ratchet then used a pawl to hold it in the firing position thus not stressing the motors.
Unread 07-01-2016, 21:46
apalrd's Avatar
More Torque!
VRC #3333
33 2014 used a NBD ('Nothing But Dewalts') transmission with the CIM interface. We had ordered a huge number of DeWalt replacement parts when NBDs were popular and are slowly using them. I wouldn't recommend it for new designs. If I did it again I would probably use the ratcheting wrench trick (using a 1/2" ratcheting wrench on a 1/2" hex shaft) on some intermediate shaft in the gearbox.
Also the example gearing is not what 33 ended up with, but it was an early iteration.
The entire purpose of the spreadsheet was to investigate different locations for the pivot and the pin, based on the start/end force of the spring.
There are two geometry points on the choo-choo. The first is the diameter of the disc. The second is the length of the 'fling' arm (blue in the illustration above).
During the first half of the rotation, the pull-in length will be 1 diameter of the disc and the torque lever (torque applied to the motor) will be 1 radius of the disc. During the second half of the rotation, the pull-in length will be (fling length - radius) * 2and the torque lever will be (fling length - radius).
If the spring force starts at 0, it would be ideal to make the fling 3/4 of the diameter. The first hump would then pull in 2/3 of the total pull-in length with a longer torque lever (more torque on the motor), the second hump would pull in the other 1/3 of the total pull-in length but the torque lever would be shorter. Since the spring force is constantly increasing, the torque seen by the motor will be equal between the two humps.
As your spring equation changes, you can play with the diameter and fling length to get the total pull-in distance that you need along with balanced torque humps for fastest pull in.
The pin location doesn't matter at all, it can be anywhere on the disc as long as it pushes the fling arm. 33 2014 used the driving axle as the pin and made a notch in the fling arm for the axle (with a thick washer on the end) to nest into. I'll see if I can find pictures.
This is true. However, the 'null sector' would actually be a slight reversing of direction and the total pull in distance would be reduced (it would pull in the mechanism a bit too far, let it out a little, then let it go).
Unread 07-01-2016, 22:51
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Does this mean that the "cocked" position could require exactly zero force to maintain (though it would be metastable, at the "top of the hill")? If so, I like it even better.
Unread 07-01-2016, 23:12
Aren_Hill's Avatar
Build Nifty Things
The Choo Choo is a favorite mechanism of mine, Dillon Carey and myself have a fancy version of a Choo Choo sheet with graphs and a rewind time calculator as well. (He did most of the work)
The first rendition of this mechanism I used in FRC was 2008 on 1625, with a fisher price motor in a Nothing but Dewalts setup for anti-backdrive.
Second implementation was 2010 for the kicker, same deal.
Then when 2014 rolled around and Build Blitz was happening....yup
Also Versaplanetary and a ratcheting wrench? way easier than dewalts.
Killer Bees were just the first people I've seen actual math from.
-Aren
A guy who likes robots.
Unread 07-01-2016, 23:32
http://www.chiefdelphi.com/forums/sh...96&postcount=9
Unread 08-01-2016, 07:37
apalrd's Avatar
More Torque!
VRC #3333
I did a reverse image search on my saved copy and it didn't find it anywhere on the internet. I thought it had been lost. I guess it doesn't index CD attachments.
