Go to Post And you said it would be an easy game hint... Time to break out the N-Spire and do some number crunching - CalTran [more]
Unread 06-01-2016, 14:46
Beaker's Avatar
Beaker Beaker is offline
624 Programming Alum
AKA: Justin K.
no team (No Team)
Beaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to behold
Re: pic: Team 624 2015 Offseason Tesbed
Originally Posted by philso View Post
That is pretty good performance. Does the amount of drift or the distance driven change if you reduce the acceleration to half or if you double it?
The distance does not change if we adjust acceleration, only the time it takes to travel the distance given. This is because the profile recalculates the motion profile with the new values. The drift also does not change.
Team 624 (Student) 2013-2016
BBQ FIRST Creator
Unread 06-01-2016, 16:58
Jack S.'s Avatar
Jack S. Jack S. is offline
FRC #0624 (CRyptonite)
Jack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud of
Alternatively, you can install all your electrical components on a thin polycarbonate panel then attach the panel to the pan.
This is the approach we used with the testbed. However, I would have preferred to design the pan based on the electronics layout like you suggested, but we were in a time crunch. If we use a belly pan this season (I hope to, but in my memory I don't believe we ever have), we will most likely trim down the weight and base it off the electronics layout.
2013: 1539 Clover Robotics
2014-2016: 624 CRyptonite
Unread 07-01-2016, 13:17
shlynfrhm shlynfrhm is offline
FRC #3039 (Wildcat Robotics)
shlynfrhm is an unknown quantity at this point
Hi, can any of you clarify what type of thin polycarbonate paneling you would reccomend to mount your electronics on? And what reccomended thickness? Thanks!
-Ashlyn
Unread 07-01-2016, 13:27
philso philso is offline
FRC #2587
-Ashlyn
These last two years, we mounted all the electronics on polycarb panels. I think we used 1/8 inch thick polycarb both years.
In 2014, the components were pre-assembled onto the panels outside of the robot. The panels were then stuck onto metal panels in the chassis using Velcro. The polycarb panels were fully supported by the metal panels so we could have used 1/16 inch thick polycarb for these if we had any.
In 2015, the panel (about 16 x 22 inches) was riveted to the frame tubes and was only supported around the edges so 1/8 inch thick polycarb would be needed to prevent the panel from flopping around too much once the heavier electrical components were installed. There was a second polycarb panel mounted on the other side of the tubes with the pneumatic components mounted on it. Don't make the mistake of installing anything on the panels with screws and nuts. The nuts were inaccessible once both of the panels were installed.
Unread 08-01-2016, 23:53
tomer tomer is offline
FRC #4590 (GreenBlitz)
Team Role: CAD
tomer is an unknown quantity at this point
Originally Posted by Jack S. View Post
Looks Awesome!
We have been working on something similar, without the chain in tube design though..
Could you elaborate about designing and assembling chain in tube systems?
In addition, what are the gearing ratios for the drive train? + Which sprockets are used? Any tensioners?
Thanks
