Go to Post Don’t choose to aim for the stars because they mark the peak of our abilities, don’t choose to aim for the stars because it is easy, choose to aim for the stars because it shows the depth of our potential; choose to aim for the stars because it is hard! - Ken Leung [more]
Unread 03-01-2016, 21:42
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
Team 862 Base Code
Generic code for a tank based arcade controlled robot. Pretty clean, nice logging, a rudimentary implementation of 254 motion tracking auton.
https://github.com/frc-862/2015-Base.git
There is also a nice little C++ web server we plan on using to manage configuration files and viewing logs. Very little of the the HTML is done; however, the C++ server is complete and functional at:
https://github.com/frc-862/roboconfig.git
Not necessarily saying this is 100% perfect, but it is where we are starting this year, good luck everyone, see you on the field.
Unread 05-01-2016, 09:00
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Re: Team 862 Base Code
nice code. I like the organization. How do you like the nvax?
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 05-01-2016, 09:07
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
How did you like GitHub with LabVIEW? I have heard very mixed opinions on if it's worth it or whether there's a better way.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 05-01-2016, 11:15
Programming Mentor
I like the NavX. We did find there was an issue using it and the CAN Talons in a high speed control loop (< 20ms). Moved the NavX code to its own loop, and everything worked great.
We have not yet integrated it into the auton motion profile code, but that is on the list. Hopefully it will make things more precise, time will tell.
As for GitHub and labVIEW -- the real question is labVIEW and any version control system -- they are almost all designed to work best with text files, so labVIEW's binary format adds lots of pain points. It works, but merging is very difficult. The big trick is to never let more than one person, work on the same VI at a given time. One of the main reasons we are looking into switching to Java is for better code merging.
Unread 07-01-2016, 19:46
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Hey phurley,
I'm just wondering what type of issues you were seeing, were they with the navX Library or the CAN Talons?
Quick question, why did you need to separate the navX get of YRPHfH to a loop? I also noticed that you were refreshing your navX processing loop at 5ms while you have the navX updating at 50Hz (20ms). Is there a reason as to why you are looping that fast? You will only be receiving new data from the navX at 50Hz.
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
