Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 07-01-2016, 20:06
richtop richtop is offline
AKA: Richard Topolewski
FRC #5053 (Laker Robotics)
richtop is an unknown quantity at this point
Java Code Release with Easy Motion Control
Including easy to use Motion Control for Java (well I think it is easy, at least that was the intent).
2016 Start Java Code
https://github.com/LakerRobotics/FRC2015Java.git
  • Includes an easy to use Motion Control to drive in a straight line. It allows you to specify the distance, a max-speed and a ramp-up/ramp-down zone. It includes Gyro controlled straight line adjustment. Compatible with WPI's Robot Builder.
  • Includes an easy to use motion controlled turning. Controls speed of rotation using a gyro, again with a ramp-up/ramp-down zone and a maximum speed of rotation. Compatible with WPI's Robot Builder.
Unread 07-01-2016, 20:40
c0d3rman's Avatar
c0d3rman c0d3rman is offline
Programming Captain
AKA: Yoni Lerner
FRC #4904 (Bot Provoking)
c0d3rman is an unknown quantity at this point
Re: Java Code Release with Easy Motion Control
Cool stuff!
You should add that description to the readme on Github - makes life easier.
Also, why all the temp files? You should gitignore those.
Unread 08-01-2016, 00:18
Thanks for the kind words.
Ya the ~ Temp files is kind of embarrassing. I did add *~ it to the .gitignore file, after I saw the ~ files, but the original ones had I to be removed. It has been cleaned up.
I also added some description to the readme.md file as suggested.
