Go to Post FRC: so inspiring, even car thieves can't handle it. - evanperryg [more]
Unread 26-03-2003, 11:06
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
I've used the PICStart Plus quite a bit - it's $200 from digikey, but it's been out long enough that you might be able to find one on ebay. Lately I've used the PIC-ICD quite a bit - you can get it for $100, but it's more complicated to use, and it only works with the 16F87x chips. But it lets you pause and debug programs on the chip in the circuit, which is a really neat feature.
If you can afford it, the PICStart Plus is probably the way to go. It's well integrated with the MPLab software and it's really easy to use.
If not, I've also used the EPIC programmer here: http://www.melabs.com/products/epic.htm
It uses the parallel port, isn't integrated with MPLAB, and for some reason, I was unable to run it under Windows NT, but once I got it working, it was very solid, and it let me do in-circuit serial programming, and it's only $60.
There are also plans all over the web for different kinds of programmers, just ask the goog
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Calling all PHP/ASP programmers! blueWarrior FIRST-related Organizations 15 27-01-2004 13:24
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
