Go to Post I'll wait for someone else to do it, then disagree with whatever they say. :p - Jcarbon [more]
Unread 07-01-2016, 21:55
lakecat's Avatar
lakecat lakecat is offline
Cat Expert
AKA: Tristan Thompson
FRC #2635 (Lake Monsters)
lakecat is an unknown quantity at this point
Recycle Rush Code
We decided to switch from LabView to Java for this upcoming season. We ended up reprogramming all the robots from 2013-2015, and through this process found much success using the Strategy Pattern for our software architecture. Our Recycle Rush code offers a good example of this:
GitHub: https://github.com/ultr4son/LiftBotJavaV2.git
We also compiled a library of commonly used objects, called LakeLib.
Github: https://github.com/2635Lakemonsters/LakeLib
Teams are free to use this library and give suggestions on its improvement.
Unread 07-01-2016, 22:51
c0d3rman's Avatar
c0d3rman c0d3rman is offline
Programming Captain
AKA: Yoni Lerner
FRC #4904 (Bot Provoking)
c0d3rman is an unknown quantity at this point
Re: Recycle Rush Code
That's really cool! Have you seen Command Based programming with wpilib? It looks like that's along the lines of some of the stuff you're doing here.
