Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Unread 07-01-2016, 00:45
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Re: Index of Robot Code Releases
Here is our java code for team 3944 All Knights.
Our code is for mecanum drive.
Here is the link to githubhttps://github.com/AnnaDtest/AllKnights2015.git
and
separate CD post here: http://www.chiefdelphi.com/forums/sh...d.php?t=140981
Thanks for taking this on!
Unread 07-01-2016, 05:58
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Beast Robotics, Team 2202's code for Recycle Rush is available at:
https://github.com/2202Programming/2015
Code is in C++/WPILib. It was the first year we used mecanum drive.
The team is also in the process of implementing token commands. Kind of like an interpreter. You provide a table of commands, and the program executes them.
In 2015, the team substantially modularized most of the functions which are called by the main process. In 2016, we hope to rewrite the main process to be a command interpreter that will then call each independent module at the appropriate time.
Unread 07-01-2016, 15:24
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Originally Posted by Colby Skeggs View Post
Good thoughts, but as the single person maintaining this repository, I'm not certain I want to have to process 1000 entries manually.
In that case, I would recommend getting additional people to help you, particularly if you made the list without planning on it growing to a substantial size. That or, ideally, using a wiki or something in The Blue Alliance instead (for ease of editing, and unity with other information, respectively)
GSR Dean's List Finalist 2011
Unread 07-01-2016, 15:26
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I think the blue alliance would be the ideal place for this sort of thing. There's a pull request that I saw that has inclusion for links to team's github accounts, they might be open to this sort of thing too.
Having a single flat list will get unwieldly very quickly.
Unread 07-01-2016, 18:57
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Team 2990 Hotwire: https://github.com/HotwireRobotics/2015FRCRobot
Nothing special. Tried introducing the NavX, but it was still in beta, so we decided not to use it at Worlds. We also implemented stops on our lift and a limit switch on the carriage so that it would know where it was (which "level").
CD post: http://www.chiefdelphi.com/forums/sh...73#post1517773
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 07-01-2016, 19:54
richtop richtop is offline
AKA: Richard Topolewski
FRC #5053 (Laker Robotics)
richtop is an unknown quantity at this point
Team 5053: Laker Robotics (Labview & Java) including easy to use Motion Control for Java (well I think it is easy, at least that was the objective).
2015 Labview Code
https://github.com/LakerRobotics/FRC2015RobotCode.git
  • latest labview Code for competition 2015 robot is available in the "Off-Season" release/ tag. It includes code to read the AMS Hall Effect sensor AS5048A-EK-AB over I2C, used as an infinite POD for our elevator
2016 Java Code
https://github.com/LakerRobotics/FRC2015Java.git
  • Includes an easy to use Motion Control to drive in a straight line. It allows you to specify the distance, a max-speed and a ramp-up/ramp-down zone. It includes Gyro controlled straight line adjustment. Compatible with WPI's Robot Builder.
  • Includes an easy to use motion controlled turning. Controls speed of rotation using a gyro, again with a ramp-up/ramp-down zone and a maximum speed of rotation. Compatible with WPI's Robot Builder.
Unread 07-01-2016, 22:19
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
nandeeka is on a distinguished road
Thanks for compiling this resource.
Team 1868's code can be found here:
https://github.com/team1868/SCcode2015
The CD post can be found here:
http://www.chiefdelphi.com/forums/sh....php?p=1517876
Unread 07-01-2016, 22:31
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
As suggested by multiple people, I'm doing a couple of things:
  • I'm restricting further additions to pull requests.
  • I'm bringing on at least a second person to help review PRs.
Specifically, don't just post your code links in this thread. Send a pull request to the repository. (If anyone has a link to a good guide on sending PRs, let me know and I'll add it to the repo!) I've also added a contribution checklist, which lets you know what I'm (and in a moment, other people are) looking for in your PR.
Shout-out to Emile Hamwey from 3467 for offering to help review pull requests! I'll see how the load gets, and we can add more people as necessary.
Re: GitHub not being the right platform: you're probably correct. We'll do it like this until we see if it's good enough or if we need something else.
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
Unread 08-01-2016, 10:57
Team 2202, Beast Robotics
Current progress on porting last year's C++ code to Java.
https://github.com/2202Programming/JavaTesting
Unread 08-01-2016, 11:35
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Mecanum/NavX-MXP Drive System Code (Java):
  • Upgraded to support TalonSRX in speed mode.
  • Rotate to angle/Drive Straight PID Controller
  • Field-centric drive
  • Several Joystick response curves
https://github.com/Kauaibots/FRC/tre...veMule2016/src
LED Strip Code (Java):
https://github.com/andrew-cadwallade...dressable-LEDs
(Re-post of original post by Tythax)
Unread 08-01-2016, 11:42
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
https://bitbucket.org/987Coders/987_2015_release/src
2015 robot + scripting
FRC Team 987 - It's not enough
Unread 08-01-2016, 19:12
*snip*
*snip*
Originally Posted by Gigakaiser View Post
Can you three please send pull requests directly to the repository?
