Go to Post It would be interesting to be able to take robots from multiple years and invent new games they can play together (Calvin Ball). - Mark McLeod [more]
Unread 07-01-2016, 22:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: Apalrd's Choo-Choo Analysis Spreadsheet
Originally Posted by apalrd View Post
This is true. However, the 'null sector' would actually be a slight reversing of direction and the total pull in distance would be reduced (it would pull in the mechanism a bit too far, let it out a little, then let it go).
Does this mean that the "cocked" position could require exactly zero force to maintain (though it would be metastable, at the "top of the hill")? If so, I like it even better.
