Go to Post When someone asks me to define Gracious Professionalism, I'm just going to send them to AndyMark. - rsisk [more]
Unread 07-01-2016, 23:19
Michael 4499 Michael 4499 is offline
FRC #4499 (The Highlanders)
Michael 4499 is on a distinguished road
Off-season chassis
This is the grabcad for last year's offseason chassis that my team worked on and built. It is designed to weigh around 25-30 lbs with all of the hardware on it.
EDIT: IN THE GRABCAD OPEN THE ASSEMBLY CALLED TB2_base.asm I hope this works
2016 Galileo & Carson - Gracious Professionalism
2016 Colorado - Chairman's award, Finalists
2016 Arizona North - Engineering Inspiration
Unread 07-01-2016, 23:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Off-season chassis
The assembly is not showing up for me on GrabCAD. Could somebody double check that it's not just me (or GrabCAD + Creo)?
Unread 07-01-2016, 23:29
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Most WCD I've seen have the chain or the belt behind the wheels. I've always assumed that the intent is to protect the chain or wheel from caught when the robot is hit from the side. Are you concerned about that?
Edit: I'm going by the picture, I can't get the CAD either
I just uploaded the folder with all of the files, I think it should be in there.
Unread 07-01-2016, 23:32
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The picture you have is enough, although the model doesn't load for me; kind of odd.
Building on what Chak said, you may have trouble mounting bumpers on there without extending the front/back rails.
I love the lightening pattern (seems strong but light), and the use of what appears to be 2x2 tubing everywhere. Have you considered adding a bellypan for stiffness?
Unread 07-01-2016, 23:36
This robot is not FRC legal, it is just a simple bruiser bot and it will have bumpers on the side of it. One problem I can see in this chassis is after enough wear the belts might stretch too much and come off of the pulleys.
Unread 07-01-2016, 23:38
Close, it is 2x1-1/2 tubing everywhere and although not in cad there will be a carbon fiber plate on the belly of the chassis.
Unread 07-01-2016, 23:42
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Nice work!
Why carbon fiber over "cellulose fiber"? Wood tends to be nearly as strong and light, but is far cheaper and easier to machine. And the frame is plenty sturdy to make up for any loss in strength?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 07-01-2016, 23:48
Originally Posted by z_beeblebrox View Post
Nice work!
We really like to use the carbon fiber that is thin (1/16") and it is still strong enough to support an electronics board. With would it isn't possible to go as thin as you can with carbon fiber.
Unread 08-01-2016, 00:10
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I know what you mean. We did carbon fiber last year and it was a little lighter and thinner than a wood belly. We mostly did it so our kids could have the experience of creating the layup, because the gains were small and were offset by other factors (cost especially). Still, you guys were the coolest team in Colorado last year, so I ain't gonna try to advise you. Looking forward to what you come up with this year!
http://www.angelbotics.com
Remember why you're doing this.
Unread 08-01-2016, 00:20
Thanks a lot, you guys had an awesome robot last year and your team did very well in the tournament. We have a carbon fiber fanatic on our team it is really not an option to go back to a wooden belly. I hope to see you guys at the competition this year, best of luck.
Unread 08-01-2016, 02:06
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
It also shortens the moment arm of the cantilevering force on the axle. On this chassis, the tension force carried by the belts will have ~5x the ability to bend the shafts compared to if the belts were right against the chassis rail. Also, when the shafts do deflect (either from the belt tension, or force on the wheels), the pulleys will move ~5x as much, which means your belts will be more out of alignment.
FRC 766, 2015-, Mentor
