Go to Post There are "Problems", and then there are "Solutions". Understand the Problem, and keep your mind open to alternative solutions. Don't get married to a Solution. - rich2202 [more]
Unread 05-01-2016, 23:10
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
What battery chargers ?
What battery charger have teams found the best to use ?
Unread 05-01-2016, 23:27
Bob Steele's Avatar
Bob Steele Bob Steele is online now
AKA: Bob Steele
Re: What battery chargers ?
We use a pair of these:
http://www.andymark.com/Battery-Char...-p/am-2026.htm
They work pretty well.... and 2 will charge 6 batteries at the same time.
Unread 05-01-2016, 23:32
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
This is the charger we use at CTRE.
Its a bit pricey but it charges eight batteries at a time.
So far, no complaints - works well.
http://www.boatandrvaccessories.com/...g-station.html
For single-battery chargers I've used regular $80 automotive chargers from the closest hardware store, with a wide range of success (some terrible and some great).
Unread 06-01-2016, 01:05
Kenny Cheung Kenny Cheung is offline
FRC #0008 (Team 8)
Kenny Cheung is an unknown quantity at this point
We use one of these http://www.amazon.com/HiTec-44169-4-...=hitec+charger as our primary charger/maintainer with a couple of the KOP ones as backups.
It has four really nice displays (one for each battery) that tells you the current voltage and charging amperage. It also has some "PC link" features that allow you to access charging data on a computer but we have not taken advantage of that feature as of now.
That particular model requires you purchase an external PSU but there is a more expensive one that comes with one built in. We chose to get our own cheap power supply but I would recommend against it because its became a pretty big hassle (we needed to add fans to cool the PSU, etc...).
Team 8:
Paly Robotics
2016-present | Team Captain
2015-2016 | Build Captain
2014-2015 | Lab manager
2013-2014 | Build Team Member
Unread 06-01-2016, 06:48
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
http://www.amazon.com/Battery-Tender.../dp/B000NCOKVU
We got this one locally for a little less than amazon had it. Price worked out to be a little more than two of the ones linked above at Andymark, but it charges and maintains 10 batteries. We've had it for a few years and have noticed very little change in battery health (max voltage, sustainable amps delivered under load, etc) since. We are still able to use batteries several years old for heavy practice bouts or for a competition if necessary. At competition, by the time you use battery five or six, battery one is charged and maintaining.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 06-01-2016, 14:43
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
This would be illegal as it is capable of charging in excess of 6amps.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 06-01-2016, 18:30
bcampbell's Avatar
bcampbell bcampbell is offline
bcampbell will become famous soon enoughbcampbell will become famous soon enough
We use Auto Meters BUSPRO-660. It charges 6 batteries independently of each other at the same time and has indication lights for charge levels as well as if the charger detects problems with any of the batteries. The charger will adjust voltage/current once batteries are charged and will maintain a full charge on all of the batteries.
Here is a link to the product page. http://www.autometer.com/6-station-a...-115v-agm.html
We also created a battery cart designed specifically for this charger with the charger mounted vertically. The cart hold 10 batteries (6 charging and 4 storage) and has wheels for easy transportation to events
Unread 06-01-2016, 18:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Any pictures of the cart?
Unread 06-01-2016, 18:40
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
+1 to bobs reply. We like ours. And I can get cart pics for you
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 06-01-2016, 18:45
bcampbell's Avatar
I don't have any pictures on this computer but I do have a solidworks rendering on a flyer. We also posted the cad files on our Google drive as well as grabcad so if you are interested in looking at our cart you can. We also included assembly instructions. Ill try to get a picture next time I am at the shop.
Unread 06-01-2016, 19:46
Big discussion on that last year. I think we came to the conclusion (after someone asked HQ) that it's legal to HAVE the charger, but not to USE the >6A charging option. And if the inspectors see it, you can expect random spot inspections of your charging.
Unread 06-01-2016, 20:50
Cool, thanks. You'll have to stop by our pit area at Long Beach.
Unread 08-01-2016, 00:03
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Not last year, but 2 years ago, I was part of that big discussion and asked the GDC. We have some stanley 15A chargers which we use to top off/float charge our batteries during competiton. We were getting horribly inconsistent performance from what we had which is what we still use to do the bulk charging but using these allowed us to solve the problems we were having. It's legal as long as at no point more than the manufacturer's recommendation(6A) is being charged to the battery.
Unread 08-01-2016, 00:23
Of course, there's one big problem with this statement...
I have the 2016 Game Manual on my desktop, but no password (yet--give it less than 36 hours and we'll take care of that). We'll find out whether this is still the case for this year when we can open the rules.
Unread 08-01-2016, 01:34
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
FRC 4607 does have a couple of Dual Pro SR3 chargers from AndyMark. They are great and we have had no problems with them charging our batteries...
BUT,
if I could go back and redo our purchase, I would go for the Battery Tender as it offers more charging stations and is more compact than our two Dual Pro SR3's. When space is a commodity in a PIT, every inch counts.
Just my two cents.
"An error does not become a mistake until you refuse to correct it" ~JFK
