Go to Post Also, I did not know that Autodesk had changed our name from WildStang to "Digital Cheetanators"? - Raul [more]
Unread 08-01-2016, 07:39
Robopromo's Avatar
Robopromo Robopromo is offline
FRC #2474
Robopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of light
pic: Team Standards from Robopromo
Unread 08-01-2016, 07:40
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: pic: Team Standards from Robopromo
This looks like a really nice product, I just have a couple of questions:
- What material are the standards made of?
- How are the edges finished?
- What type of iron on vinyl are you using?
Thanks
Unread 08-01-2016, 09:25
Robopromo's Avatar
FRC #2474
Thanks
Good questions. Thank you for asking. The material itself is 200 denier nylon. The pieces are CNC cut and the edges are heat-sealed. The decals are standard iron-on vinyl and come in white or black.
Send us your own artwork and team numbers and we can cut them and send them to you or apply them for you in our shop.
Unread 08-01-2016, 14:20
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Looks awesome!
What was the final weight using the nylon?
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 08-01-2016, 14:28
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
What kind of standard vinyl? Is it Digi-Cut, Siser, Chemica? Hot peel, cold peel? matte, semi-gloss or gloss?
The different brands have different qualities to want or avoid, and make a huge difference in durability due to use. Also if a team decided they might want to layer another vinyl on top they might need to know brands as many don't play well together and result in some oddball melting and running colors, or poor adherence.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-01-2016, 18:56
Robopromo's Avatar
FRC #2474
The vinyl is CNC-cut and is semi-matte. It can be layered (plays well with others).
Unread 11-01-2016, 19:00
Thanks, I'll let our local teams know that aren't on here often!
Andrew Basse
Unread 12-01-2016, 17:51
oliverchuckle oliverchuckle is offline
FRC #5416
oliverchuckle is an unknown quantity at this point
Is there any limit to the size of the decals?
Unread 12-01-2016, 21:04
Robopromo's Avatar
FRC #2474
The only width limit is the width of the material, which is 12" (FIRST regulation for the team standards).
Unread 11-02-2016, 19:19
FRC BOTMOM FRC BOTMOM is offline
FRC #3319 (G.R.E.A.T)
FRC BOTMOM will become famous soon enoughFRC BOTMOM will become famous soon enough
Send a message via AIM to FRC BOTMOM
Would you be able to do a standard in a custom color like orange?
